Bat poopI understand that make up products are made with bat poop, I wounder if mixing a 50 50 mix of water and Dawn would do to it ?
I have seen that before.That's what I figured.
That image clip is from a set of Commando covers being sold for $400.... ... but my stock 273 covers have the same issue. Driver's side, lower, center bolt hole
Yep, eye shadow and other make up productsBat poop
Thats common to any sheet metal cover where the human beans repeatedly tighten bolts rather than replace leaking gaskets.This seems to be a pretty common occurrence with SB valve covers... Does this split render them unusable?
$400 ouch! My be it's from using cork gaskets and having to crank them down so tight to seal. I think the originals were rubber.That's what I figured.
I didn't click disagree because I'm not absolutely certain, but I do think OEM were cork gaskets. Along with china rail gaskets and others.$400 ouch! My be it's from using cork gaskets and having to crank them down so tight to seal. I think the originals were rubber.
looks like it would be a nuisance, have to land in winnipeg as a point of entry for customs.And coming over the boarder I wounder if I could bring anything in the way of food for the party. I'll have to find out.
Agreed, I have never owned one from when it was new. The ones I started out with had the black rubber gaskets. As early as a 65 HP273 in 69. THey could have been cork originally.I didn't click disagree because I'm not absolutely certain, but I do think OEM were cork gaskets. Along with china rail gaskets and others.
The trick to success with cork gaskets is use a ball peen to dimple the bolt hole upward. Tighten the bolts only enough to flatten your dimple. Seal is supposed to be from bolt to bolt, along the flat spans, not and the bolt alone.
273 is a LASo I have no idea are 273 valve covers different than a la?
Pretty cool. Hety didnt Eric go down there on the MrNorms stuff?
Search Our Bulletins - McCandless Collection
Mike, is that a legit cigar? Or is it filled with something else?
