I would pin a fiberglass hood for sure.I would have to remove the fender. I don't think there is an easier way to do it.
If I have to remove the fenders, I am leaning toward pin on and removing the hinges entirely.
Yeah I mean get one that only pins on and not get the bolt-on version.I would pin a fiberglass hood for sure.
Depending on the company Glasstek makes bolt-on and pin-on. Some only make a full pin on hoodsNever knew there was a difference thanks.
Think I got the mower deck working like new again, figures after I found some one to cut the lawn..........Nothing is ever easy.
My 64 had torsion bars I cut them off and use a prop rod to hold it up.I would have to remove the fender. I don't think there is an easier way to do it.
With a fiberglass hood regardless of how you mount it make sure you use hood pins on the front. Too much flex at high speeds and it will unlatch....Oh good MorningDepending on the company Glasstek makes bolt-on and pin-on. Some only make a full pin on hoods
..??Ray what did you do?
I went pin on. Easier, cheaper and LIGHTERI would have to remove the fender. I don't think there is an easier way to do it.
Yes super nice also.Is that the one in Hazelton PA? $275
LOL just posted that!Another thing I am looking at is getting the new hemi scoop and modifying my current hood...................
I highly recommend Glastek out of Illinois. My 74 dart hood (same as a 69 cuda) fit perfectlyThe issue is the current hood with the snorkel scoop will not fit the cross-ram. Snorkel scoop is too narrow.
My calendar is different!
I am going with the hemi super stock scoop, just a matter of how..................new or try to add new scoop to existing hood.
