Mitch if you have parts numbers my buddy can get the parts usually cheaper than deere.
Yep… 1964 Plymouth Sport Fury. 383-4 barrel, 4 speed. Turquoise with matching interior please.Lol. Does this mean you all will start distributing wish lists also?
Thanks buddy. I have my sources.Mitch if you have parts numbers my buddy can get the parts usually cheaper than deere.
Yeah, I didn't know anything about this until it went up. But apparently around 1,000 hours. The plastic camshaft gears on these 22 horsepower Kawasaki engines fail. Looking into it, it's not that hard to repair. But I need to get it apart to see if it bent any of the push rods or not before I order the parts. Probably pull the heads off of it and look at the cylinder bores as well.Is that the engine with plastic in the wrong places, weird.
Hopefully things are straight, good luck! Lost a timing chain once on a Toy motor, bang, valve job.Yeah, I didn't know anything about this until it went up. But apparently around 1,000 hours. The plastic camshaft gears on these 22 horsepower Kawasaki engines fail. Looking into it, it's not that hard to repair. But I need to get it apart to see if it been any of the push rods or not before I order the parts. Probably pull the heads off of it and look at the cylinder bores as well.
At least the whole car isn't going in there, still could work on other things if needed.Body shop is not the fastest, but local. Not like everything is done anyway so no big deal
Yeah no plans to do anything to the car. Just changed things for safety and reliability. I have front end parts coming today.At least the whole car isn't going in there, still could work on other things if needed.
Weird, Tempest Craigslist is giving me a lot of "your request has been blocked", hmmm.
So you have crossram problems, what a nice problem to have lol! Good luck with the scoop!Yeah no plans to do anything to the car. Just changed things for safety and reliability. I have front end parts coming today.
The hood was a mess and I have to do something due to the crossram. No way the current scoop would work.
Not sure what was happening, maybe I'll start over and see if still happening because it started the search in the middle of the listings, maybe where I left off yesterday...VPN running?
YeahSo you have crossram problems, what a nice problem to have lol! Good luck with the scoop!
I don't no and I haven't violated any of C lists rules. I may respond to the "click here" and see if it gets resolved, I like using Tempest from time to time.VPN running?
Ah the black and pink rainbows, my favorite!!!
