At work, an unexpected, unplanned self disassembly leading to ventilation. Mechanical failure, not a result of rapid expanding flammable air.
Sounds like a Butt crack vented!At work, an unexpected, unplanned self disassembly leading to ventilation. Mechanical failure, not a result of rapid expanding flammable air.
And I can assure his drive is in fact long and narrow. My race trailer took up every bit of it on width. When backing trailer up. you can Keep trailer on drive or keep truck on drive, pick one! It is a twisty narrow drive for sure. I backed up to park as I did not want to try it in the dark when I left.I use these two. The ready mix I use for bigger cracks and work it in usually a couple applications with a day between to let the first one dry. The second one is like a thick liquid it fills easy, and I just smooth it out with a couple fingers. The secret is when you open it the first time not to cut too much off the tip. Too big it comes out heavier than what you’d really want. Both work week used them for a couple years. I buy them at Lowe’s in the masonry section.
Yep just picked up a 25x set of binos.Anyone else been hitting the Amazon Prime-Day deals? There's some good ones in there... things I've had on my list.... just hadn't pulled the trigger.
??????Yep just picked up a 25x set of binos.
Got a bunch already, I live on it for range days in summer.Liquid IV is a good deal as well
Ahhhh Makes sense now.25 power binoculars
I print postage out fills half a page so it goes fast.
Laserjets much better $$ as long as its black and white and graytone printing.Work upgraded me to one of those Epson tank printers. Seems to last longer than the cartridge ones
So much more fun to do the R&R when it's 8' off the groundAt work, an unexpected, unplanned self disassembly leading to ventilation. Mechanical failure, not a result of rapid expanding flammable air.
I finally got tired of the inkjet B/S and I bought a Brother color laser. THe color is not photo quality but darned close to it. I finally had to replace the black toner cartridge and I see the yellow is getting low. The cartridges that come with the printer don't have much inside but it was enough to last us a year so far.Laserjets much better $$ as long as its black and white and graytone printing.
HP laserjet P1102 is what I use for 98% of what I print.
