Are you talking about fender nuts . (Karl)Hey question.... on our cars, where a bolt goes through sheetmetal and there is the "nut" that slides over the other piece. What are those officially called? Body bolts/clips?
I actually just found it. Body bolt and U nut clip. I have been Strategic Transfer Equipment to Alternate Location.... I mean grabbing them as I find them but need a bunchAre you talking about fender nuts . (Karl)
bulk packages? I see they sell them in 25pcs packs on Amazon for $32Erkic I got mine from Fastenal actually for the Dakota
More than I want to buy. It is for putting the Charger together. It would be best to make the trans tunnel and many other panels removable if possible. Will make working on things much easier. I have a bulk pack of Dzus fasteners but not enough and haven't used them before...yetThink so. How many you need?
Used them on outside aircraft panels, work great and fast on and off.More than I want to buy. It is for putting the Charger together. It would be best to make the trans tunnel and many other panels removable if possible. Will make working on things much easier. I have a bulk pack of Dzus fasteners but not enough and haven't used them before...yet
The Dzus? Yes, I know they are super handy but I haven't installed them yet to know what a pain that is. I know there are different depths for whatever you are connecting, the spring things, etc. So, I wasn't sure if I should just use the body bolt set up.Used them on outside aircraft panels, work great and fast on and off.
Nut clips?Hey question.... on our cars, where a bolt goes through sheetmetal and there is the "nut" that slides over the other piece. What are those officially called? Body bolts/clips?
Morning . Just had my first coffee this morning ! Ultra sound appointment. And no I'm not pregnant !![]()
Whew...close call
To avoid that scare just remember…there are 2 other holes that won’t make a babyMorning . Just had my first coffee this morning ! Ultra sound appointment. And no I'm not pregnant !![]()
I don’t know if it’ll help, but I shared your page to a few Facebook groups.
Can you powder coat a Holley carb?
To avoid that scare just remember…there are 2 other holes that won’t make a baby![]()
Damn, the kitchen sink drain is clogged.
