Ben Drinkin
Hey bartender!
Holes? I like holes!!To avoid that scare just remember…there are 2 other holes that won’t make a baby![]()
Yep. MIL's house over T giving. I went over to Andy's house and got my drain. It is going down very slow. I'll try some boiling water and the plunger and see what it will do before I take the trap apart.Didn't you just deal with that at your mother in law's house??? You have luck like I do Mike.
Hope it's something simple.
Are you talking about fender nuts . (Karl)
Time for QA-1 ! Put them on the duster , what a difference !!Im hoping to get time to get under the dart this weekend. I noticed it’s dripping oil. It never dripped before. The steering feels off and I need to see what’s going on with that. When I hit a bump or even just a man hole cover it really grabs the wheels and pulls the steering wheel. It’s manual steering but it didn’t pull that hard before.
I am spreading the word down here in Arkansas as well. You do to good a work to be bored!Every bit of support helps and is very much appreciated!
I can do everything that doesn't come into direct contact with gasoline.
Check out @HemiDenny for tubular K frame swap he is on here and many of us run his front ends. Except for the purists, if that is important to you? Don’t know your views on modern mods. He has an excellent product, I have been trying to tear it up for years to no avail!Im hoping to get time to get under the dart this weekend. I noticed it’s dripping oil. It never dripped before. The steering feels off and I need to see what’s going on with that. When I hit a bump or even just a man hole cover it really grabs the wheels and pulls the steering wheel. It’s manual steering but it didn’t pull that hard before.
I am not a purist. I want it to run and drive. Being a cruiser is my goal since I have been driving it almost daily. Any tips or tricks on ways to make it a little better is appreciated.Check out @HemiDenny for tubular K frame swap he is on here and many of us run his front ends. Except for the purists, if that is important to you? Don’t know your views on modern mods. He has an excellent product, I have been trying to tear it up for years to no avail!
Ouch!Bad plumbing news. It is draining slow but leaking through the floor into the basement. (from a previous soil stack repair in the wall.. I have a feeling.) I called the plumber. It might be Monday.
Just powder coat or can you chrome too?Every bit of support helps and is very much appreciated!
HemiDenny makes good stuff. But I went with a Gerst coil over tubular k frame on my dart and he custom designed a watts rear for my dart. Scroll through my build thread linked in my signature and you’ll see it.I am not a purist. I want it to run and drive. Being a cruiser is my goal since I have been driving it almost daily. Any tips or tricks on ways to make it a little better is appreciated.
Factory steering boxes being worn out can cause your issue. If the tubular K is out of your price range, a Borgesan steerinfg bic upgrade and replacing your tie rods and such will tighten things up nicely . Then you can dive into bigger torsion bars and such if you want.I am not a purist. I want it to run and drive. Being a cruiser is my goal since I have been driving it almost daily. Any tips or tricks on ways to make it a little better is appreciated.
Have you rebuilt the front end.I will have to climb under and look it over and price everything out. At this point it will probably have to wait until spring. The ford is taking more time, attention and $$ than we had anticipated. But if I can at least plan it out and start gathering parts and researching how to do the work I will hopefully be better off come spring time.
If you suddenly develop bump steer, then you likely have something about to go out. You may not be able to find it just being under it. Probably should get the front end up on jack stands with wheels hanging. Tie rod or ball joint possibly.Im hoping to get time to get under the dart this weekend. I noticed it’s dripping oil. It never dripped before. The steering feels off and I need to see what’s going on with that. When I hit a bump or even just a man hole cover it really grabs the wheels and pulls the steering wheel. It’s manual steering but it didn’t pull that hard before.
Agreed!If you suddenly develop bump steer, then you likely have something about to go out. You may not be able to find it just being under it. Probably should get the front end up on jack stands with wheels hanging. Tie rod or ball joint possibly.
So just to make sure I understand , the Chevelle is in the protected coveted garage, and the Ford is now eating up the Dart upgrade parts money? What’s next ya gotta a VW in the back yard? Tell me the Dart ain’t sitting out in the snow? Cold lonely and unappreciated? Poor girl. But I reckon we will still keep ya! Clearly ya got thick skin, plus you can ride herd on hoppy. Not just anyone can do that!I will have to climb under and look it over and price everything out. At this point it will probably have to wait until spring. The ford is taking more time, attention and $$ than we had anticipated. But if I can at least plan it out and start gathering parts and researching how to do the work I will hopefully be better off come spring time.
And which does a women prefer?To avoid that scare just remember…there are 2 other holes that won’t make a baby![]()
Your a hole ***** aint you!Holes? I like holes!!
It was never rebuilt.Have you rebuilt the front end.
Yup that pretty much sums it up. Minus the VW. The poor girl does have a car coverSo just to make sure I understand , the Chevelle is in the protected coveted garage, and the Ford is now eating up the Dart upgrade parts money? What’s next ya gotta a VW in the back yard? Tell me the Dart ain’t sitting out in the snow? Cold lonely and unappreciated? Poor girl. But I reckon we will still keep ya! Clearly ya got thick skin, plus you can ride herd on hoppy. Not just anyone can do that!
It is pretty involved and time consuming but worth it when you're done. Probably the last time you have to do it. PST is a sponsor here and offers a discount. Performance Suspension TechnologyIt was never rebuilt.
What are you assembling?
It's different for everyoneAnd which does a women prefer?
