Ok people, I'm off like a prom dress...
Never seen one on a wagon before.
Surely they had to add stiffeners to the uni-body structure to keep that Impaler from bending into a U shapeThere's that style and then there's one that is essentially a 5th wheel hitch on the wagon roof..I think a single axle trailer
This
Harmon Shadow Roof-Mount RV Trailer Is The Best And Worst Of The '70s
Loadmaster translated means thankless job! They are the back bone of getting stuff moved around! Unsung hero’s!Actually used the term "Loadmistress" once with a female loady on a C-17 lift... she was very well constructed, shall we say.
I could see her processing it and trying to decide if she was offended.
She chose to smile...
We were only there for half the flight anyhow
To explain: The "Loadmaster" is an enlisted person who essentially "owns" the cargo area on the aircraft... what gets on, how it is secured, safety and how it gets off the aircraft...
When I was a firefighter we called those kind of house fires a “Scraper”My co-worker is a volunteer firefighter, responded to this call over the weekend, perhaps the green patrol down there also parked their Tesla inside the garage and lost their house.
Extremely handy until there is an electrical issue between the basket controls and the base unit and it leaves you stranded for 90 minutes unable to get to the groundLoadmaster translated means thankless job! They are the back bone of getting stuff moved around! Unsung hero’s!
Or your buddy slides by unnoticed and flips switch from basket to ground control.Extremely handy until there is an electrical issue between the basket controls and the base unit and it leaves you stranded for 90 minutes unable to get to the ground
That tooOr your buddy slides by unnoticed and flips switch from basket to ground control.
Those green energy projects are dropping like flies. Both the NJ projects that got canceled were by the company we were working for.One of them "green" energy projects?
Not enough income to support the cost of construction?Those green energy projects are dropping like flies. Both the NJ projects that got canceled were by the company we were working for.
Solar panels in spaceI think the tide generators are a pretty cool idea!
I would guess the escalating cost to borrow money is also a factor. Wife works for a very large Company tied to energy and construction. They too are seeing projects being cancelled. When the project was designed and bid the Company figures on borrowing at X percent, by the time all the red tape, permits and drawing approvals get done the interest rate on money has escalated to the point the margin is reduced and the exposure for risk is elevated. The Project managers get spooked and pull the plug.Not enough income to support the cost of construction?
The last thing I saw about that Japanese lunar lander said that it was non-functional because the solar panels on the lander were not functioning.Solar panels in space
ThisThe last thing I saw about that Japanese lunar lander said that it was non-functional because the solar panels on the lander were not functioning.
Inflation and supply line issues make the original bid's obsolete. With the increases the would post a loss with every unit they install. So yes.Not enough income to support the cost of construction?
Leonard and Sheldon strike againThis
In a First, Caltech's Space Solar Power Demonstrator Wirelessly Transmits Power in Space
I met a guy once who was working on an optical laser "pipeline" for electrical energy transport. Pretty amazing
