Bigger jetsTook 66 on 30 mile drive. Freeway and surface. Overall runs drive great. But still stumble but now further up the rpm scale.
You think?Bigger jets
Like almost Pregnant. You want my Holley back. I'm not going to use it.No leaks. Looks almost ready for power tour
Yep.You think?
Yep.
No. Stand alone MSD dist.You running a 6AL by chance? One of the issues. Scope it with the scope I gave you.
So there is a miss or stumble? At cruise or accelerating?It is for sure a fuel issue...
No miss. Been tracking off idle stumble. It seems to no longer do that. Now a bog right after the "shot" of fuel is used. Not bad, just enough to be wrong...So there is a miss or stumble? At cruise or accelerating?
What carb Tim?No miss. Been tracking off idle stumble. It seems to no longer do that. Now a bog right after the "shot" of fuel is used. Not bad, just enough to be wrong...
Maybe a squirter change.No miss. Been tracking off idle stumble. It seems to no longer do that. Now a bog right after the "shot" of fuel is used. Not bad, just enough to be wrong...
Man, I have been all thru the accel. pump settup. It might still be that, but.......To much or to little fuel? Might just be a acceleration pump adjustment?
Holley 570 Street Avenger......Holley 0-80570 570 CFM Street Avenger CarburetorWhat carb Tim?
Smaller? Make shot last longer?Maybe a squirter change.
Do you have 50 CC accelerator pump ?Holley 570 Street Avenger......Holley 0-80570 570 CFM Street Avenger Carburetor
Standard one.........Do you have 50 CC accelerator pump ?
Put one on my Holley for my 340 , what a difference.Standard one.........
Going to order one now, thanks....Put one on my Holley for my 340 , what a difference.
