Did you check the plugs. Rich or lean?Going to order one now, thanks....
Ordered.....40 bucks, not bad.......Going to order one now, thanks....
Look perfect......But still not many miles on it........BUT might be on the lean side.......for sure not rich...Did you check the plugs. Rich or lean?
Not big enough for a stroker. I have a 650 afb on my 273. I would say a 750 would make it happy or jet up the one you have. Give that a whirl.Holley 570 Street Avenger......Holley 0-80570 570 CFM Street Avenger Carburetor
Might be on to something.....Going to order jet kit. I really want to squeeze as much MPG as I can out of this. Hence, the 570.....I know just pay for the fuel. BUT 5.60 a gallon here for premium...Not big enough for a stroker. I have a 650 afb on my 273. I would say a 750 would make it happy or jet up the one you have. Give that a whirl.
Sorry, not seen that B4Got my starter. Was not expecting this… They only showed the other side. Must have been a late change, cause every one I’ve seen had 2 studs. Anyone know if this just an adapter held by the nut or hard wired in? Could it be that simple and have a stud under it? Or will I F it up if I try to remove the quick connect? I can probably find a connector pigtail , but would prefer to nut it on like the older ones.
The Holley you had on it from me is a 750.Might be on to something.....Going to order jet kit. I really want to squeeze as much MPG as I can out of this. Hence, the 570.....I know just pay for the fuel. BUT 5.60 a gallon here for premium...
I am going to put the 670 I have back on it, see if that really has any difference....Not big enough for a stroker. I have a 650 afb on my 273. I would say a 750 would make it happy or jet up the one you have. Give that a whirl.
Mine had a stumble/miss and I needed to increase the shot. Usually a heavy car or highway geared car needs a smaller/longer duration shot whereas a lighter/more geared car needs a larger/short shotSmaller? Make shot last longer?
You too, Fred!Home from work, hope everyone is having a good day.
Finger sanding sucks.What an akward place to smear filler. Never had such a problem. I guess its the narrow areas and cramped area to work. Sometimes i wish i had a seat in the cab. Not done with filler, but primed it to find the highs and lows. Too ugly for a photo at this time.
Bumble Bee That first edition mini truck that Dodge farmed out to Mitsubishi, the D50? Our desert sun baked dealer had one Brightest yellow ever, interior black and yellow striped. We swore all it needed was wings and antennae and could fly off into the Mojave to reproduce.
"Performance Based Punishment"
Anything done digitally. Takes time to master.Finger sanding sucks.
Subtle.... very subtleAnything done digitally. Takes time to master.
Yep.Subtle.... very subtle
This was a long slow *** day....
