It will in North Dakota !Does beet juice freeze?
Antifreeze weighs about 8#/gallon. How much do the tires hold? A gallon or two?I used RV antifreeze
I had a John Deere similar to Rich's and I think 4 gallonAntifreeze weighs about 8#/gallon. How much do the tires hold? A gallon or two?
How was the show?Good morning all. Have a safe trip @Mopar Tim and @dukeboy440.
Tim is off and away this morning, I’ll be linking up later once I get the tire mountedGood morning all. Have a safe trip @Mopar Tim and @dukeboy440.
Not sure yet. Friday I got the idea to see if Amazon had my tire size, sure as **** they did, it’s due to be delivered by 145pm today. So I’ve gotta call around and see who’s not only open but there’s only a couple shops around here that will mount tires not purchase through them. None of the national chain ones will.He said he was 20 or so miles from you a bit ago. What's open Sunday to get the tire mounted?
I can mount it I have that tool, I just can’t balance it. Though my tool is only ever been used on a 31 inch tire, not sure how much of a fight it’d be on a 35Good luck. Around here have friends with them in a pinch.
Is that the '66 behind that Cobra?Well hell looks like Tim found himself a convoy @Mopar Tim
Take it somewhere. If the mounting bead gest messed up it will never hold air without a tube!I can mount it I have that tool, I just can’t balance it. Though my tool is only ever been used on a 31 inch tire, not sure how much of a fight it’d be on a 35
Looks like it.Is that the '66 behind that Cobra?
Yes it isIs that the '66 behind that Cobra?
We used to use ether to seat the tractor tiresIt was always fun watching the commercial tire guys do one of the loaders at the rock farm. They used flax soap which they carried in 5 gallon buckets to seal and lube the beads when they seated them big tires. BOOM! as the tire seats and that flax soap would fly 50' in every direction
explosions can be fun tooWe used to use ether to seat the tractor tires
