You guys are getting hammered with heat over there.
For sure Chris.You'll need this for January, Fred
I mean, it's summer, so heat, yeah.You guys are getting hammered with heat over there.
I thought hotrod offered to credit Tim for power Tour west?I may be wrong, I think Chris is talking about the whole Power Tour debacle
87 and upWhat year Dakota mini starters are we using on big blocks nowadays?
Nevermind - I see now. And I may actually have one on the 360 mag I have sitting in the garage taking up space.
Yeah but talking with him at Carlisle he said he will never attend another one of their events and I don't blame him.I thought hotrod offered to credit Tim for power Tour west?
Yep. Up theresYeah but talking with him at Carlisle he said he will never attend another one of their events and I don't blame him.
Absolutely!!Yep. Up theres
Spent a lot of money to be treated like we wereAbsolutely!!![]()
That was quite the lightning show we had last night.So.. got home.. 86 outside, AC is putting out 64 which isn't too bad... on a hunch i checked and none of my air returns are pulling **** compared to what the vents are putting out, i need to find the leak and fix it.. unless my thinking is wrong that will keep the air from cycling and not help much
yeah.. this weather is getting old fast.. we had monsoon **** again this morning for a hour or so.. when we get really heavy rain for a longtime i get some water in my furnace room.. not sure where from.. maybe the weeping tileThat was quite the lightning show we had last night.
Carnage
yep I was gauntlet slapped. Game on.Carnage
Or for all y’all that think modern I got a shoe thrown at me!yep I was gauntlet slapped. Game on.
Absolutely nothing
It is nice here too.We just opened the windows, 73 degrees
ShowoffWe just opened the windows, 73 degrees
They are up there in Minnesota though. Close to the Arctic Circle!Showoff
you are probably correct with a leak. air filter clean? is it an older furnace? I believe they say not to use higher than a merv11(?) filter. when we bought our house, there was no output and then furnace shut off on high limit. checked and did not find a filter; household had oodles of children and two dogs and all carpet. found the evaporator was plugged solid. lucked out, we could pull it out and swing it around to clean without removing the Freon. good luck and hopefully it's an easy fix.So.. got home.. 86 outside, AC is putting out 64 which isn't too bad... on a hunch i checked and none of my air returns are pulling **** compared to what the vents are putting out, i need to find the leak and fix it.. unless my thinking is wrong that will keep the air from cycling and not help much
We got them bastards here too. I got some Bifen 7 that I sprayed all over. Dead grasshoppers everywhere. Not sure if you can spray it on edibles tho. Sure is fun to see them all dead tho..
