Yeah, really nice like 6" deep pleated filter i keep clean, i took the access panel off the side and checked to make sure the A coil was clean and all is good... my house is just naturally warm is allyou are probably correct with a leak. air filter clean? is it an older furnace? I believe they say not to use higher than a merv11(?) filter. when we bought our house, there was no output and then furnace shut off on high limit. checked and did not find a filter; household had oodles of children and two dogs and all carpet. found the evaporator was plugged solid. lucked out, we could pull it out and swing it around to clean without removing the Freon. good luck and hopefully it's an easy fix.
We just opened the windows, 73 degrees
It is nice here too.
Showoff
Yea I live in the frozen Tundra.They are up there in Minnesota though. Close to the Arctic Circle!
Yea I live in the frozen Tundra. View attachment 1716277143
I still got your calendar! How ya want to do the hand off?We got them bastards here too. I got some Bifen 7 that I sprayed all over. Dead grasshoppers everywhere. Not sure if you can spray it on edibles tho. Sure is fun to see them all dead tho..
CrazyCrazy couple days at work. Lost 12 hours production yesterdy when the air compressor died. Today we got hit by about the craziest storm I’ve ever seen. Took out 2 poles on either side of our entrance. Power down till….no idea. Figured out how to get everyone out of the parking lot through the grass. **** down the mains so we don’t kill anything when the power comes back ip and called it a night.
DurachioCrazy couple days at work. Lost 12 hours production yesterdy when the air compressor died. Today we got hit by about the craziest storm I’ve ever seen. Took out 2 poles on either side of our entrance. Power down till….no idea. Figured out how to get everyone out of the parking lot through the grass. **** down the mains so we don’t kill anything when the power comes back ip and called it a night.
Yep, all oK. Close call for 0ne guy I work with had just arrived (and got soaked coming in). As he got to the entrance is when the poles came down. One flamed up before it fell. Wires landed right in front of his car. Burned a line like a big black snake across the grass.Crazy
Glad everyone was OK
Timing is everythingYep, all oK. Close call for 0ne guy I work with had just arrived (and got soaked coming in). As he got to the entrance is when the poles came down. One flamed up before it fell. Wires landed right in front of his car. Burned a line like a big black snake across the grass.
Is his name Buster Keaton?Yep, all oK. Close call for 0ne guy I work with had just arrived (and got soaked coming in). As he got to the entrance is when the poles came down. One flamed up before it fell. Wires landed right in front of his car. Burned a line like a big black snake across the grass.
1000v. and lots of amps?Just found this posted by the fire dept that responded... It melted the curb!
If that came off the top of the pole it's way more than that. Like 12KV. No clue how many amps it can feed.1000v. and lots of amps?
Wow, one hell of a day for sure.Crazy couple days at work. Lost 12 hours production yesterdy when the air compressor died. Today we got hit by about the craziest storm I’ve ever seen. Took out 2 poles on either side of our entrance. Power down till….no idea. Figured out how to get everyone out of the parking lot through the grass. **** down the mains so we don’t kill anything when the power comes back ip and called it a night.
1.21 Giga watts1000v. and lots of amps?
