Yep. Circle track car alignment plays by a different set of rules.On occasion I've seen a Dirt Modified with a little extra camber dialed into that right front. It do change it's cornering characteristics.
Dragsters use the caster to change that cornering a little more to their liking.Yep. Circle track car alignment plays by a different set of rules.
Back in tech school we got graded in alignment class by how the car drove. Me behind the wheel, the instructor in the passenger seat and a student in the back seat steering the car. It should go straight down the road with hands off the wheel and the guy in the back can make it drift to the left or right by sliding one way or the other in the back seat. I got an A on that one. My 69 Road Runner.Ordered a camber/caster gauge.. kinda excited to have a car that isn't just a guess and close enough
Lots of caster.Dragsters use the caster to change that cornering a little more to their liking.
When you only have a half turn of the steering wheel lock to lock caster is very importantAI Overview
Learn more…Opens in new tab
The amount of caster a dragster runs depends on the track, driver, and goals. For example, a crew chief might use 3 degrees of positive caster on the right side and 1 degree on the left, while a rookie driver might use 4 degrees on the right and 1 degree on the left.
It holds the road better. It helps make up for Mopar's "loose feeling" power steering. I don't have much caster on my 66 (manual steering) and it is still a little tough to maneuver at low speeds.Kind of excited to see how having more positive caster will feel when driving with a older car
Outstanding! Never knew you had this education under your belt Mike.Back in tech school we got graded in alignment class by how the car drove. Me behind the wheel, the instructor in the passenger seat and a student in the back seat steering the car. It should go straight down the road with hands off the wheel and the guy in the back can make it drift to the left or right by sliding one way or the other in the back seat. I got an A on that one. My 69 Road Runner.
I have a 20:1 manual box on mine... couldn't find a pump/brackets for cheap so just got a new manual box.. prolly shoulda went 24:1, just won't try to turn when going slowIt holds the road better. It helps make up for Mopar's "loose feeling" power steering. I don't have much caster on my 66 (manual steering) and it is still a little tough to maneuver at low speeds.
No parallel parking?I have a 20:1 manual box on mine... couldn't find a pump/brackets for cheap so just got a new manual box.. prolly shoulda went 24:1, just won't try to turn when going slow
Strong arm steering!No parallel parking?
That has more chips than a jumbo bag of Freeto's.
I bet there some dents in the front of that hood so I would defiantly but some glaze over it.
When i did the manual box in the Fargo, i had buddy gently rock steering back and forth until there was very little play. Could actually feel it in the screw, as it went slack. Worked very well. 65 mph with one hand on the wheel.The little I know and I could be wrong but was taught to take the wheels off the ground and have someone turn the steering wheel back and forth a little and tighten the box up until you feel some drag on the steering wheel and back the adjuster off a 1/4 turn.
Think he had a work trip?Anyone heard from Scott ?
It's good she is working. I just got done paying some bills. $330 for utilities. (gas and electric). $224 for cell phone. (3 of us with unlimited data)I got the wife off to work. Lauren starts back with the city tomorrow. Full time employee and not a temp this time. $18/hr to start. Then I will be by myself all day! Retirement is back!
Yes , perfect...
My neck is sore alreadyHeres my view for the next few hours. Tough on neck and shoulders. Plus the climbing in and out is not easy. View attachment 1716288255
sound like my exMy neck is sore already
