terrific huh? I was thinking more like terrifying - but ok..
Hey trying to get into the glass half full mindset till Ben drinks it empty!
lNight night, Morning Morning!
I just need to snap into it... gimme about 3 hrs...Hey trying to get into the glass half full mindset till Ben drinks it empty!
How far up are your hops now? just wondering whats 'normal'. The one that did good from last year is 4-5ft up the line now. some of the new ones are around 2 ft. They are growing quick now. seems like once they get hold of the string they grow faster.Terrific Tuesday is todays theme!
the 4-5 is last years. But, those 2 got whacked by that hailstorm. newbies might be 2 ft at most. a few haven't even got on the string yet.I have a bunch up to the top wire so 14 feet or so. They are having a weird growing year for me. 4-5 is great since they just went in a few weeks ago. You beer peeing on them its like miracale grow! LMAO
I will do for sure Hops, and I am going todo a good guy alert on you and another member for all your help and taking the time and expense tom get the proper parts to me ... I wish we knew this from day one but this goes to show use old folks can still learn budLooks great! Add the stuff to the 8 1/4 thread for others. One day I will condense the info when and if I have time. Actually a lot of good info there I wish I had known about a few years ago!
Could be the advance curve. Mine has around 15 initial, with 38 total.I think I got the timing in the pop done, around 7 initial and looks like 34 at 3k. Still have a bit of a bog, starting to think one of the floats are off/leaking. shut the pump off for a bit and it gets better.
very true.If it's any consolation, that property might not have been all you dreamed of. There's so much to factor in. The side of the mountain it's on makes a big difference...north or northwest it's going to be dark and gloomy. That stream, if you want to build a bridge over it, the government requires all sorts of specs and it can cost a lot. You have to wonder what the whole story is.
that does seem a little low on initial timing - what psi are you running the pump at?I think I got the timing in the pop done, around 7 initial and looks like 34 at 3k. Still have a bit of a bog, starting to think one of the floats are off/leaking. shut the pump off for a bit and it gets better.
Same here. And tomorrow we're in the extreme risk category for tornadoes. Good thing I've got the Ram ready to go.....g'morning.. sorta. We had a line of thunderstorms roll through here at 2:45 this morning.. a couple of cracks were pretty close too, so needless to say, M3 no sleepy so good last night...
