ScampMike
Despicable Damn Yankee
man - you stripped that RIGHT down!
hey Karl - tell me about "correct" bolts in rocker arms shafts on small blocks will ya...?
How much for the quarters? Are they both that nice? Like 90% rust free!(Ok, maybe only 66%)
yep yep - got that figured - what I am getting at is that I have read/heard that there are different bolts - two of the 10 for the rocker shafts are thinner to allow oil to run up and into the rocker shafts...The bolts are 5/16" coarse thread grade 5.
The 'washers/spacers' are three small and two large. The small ones go in the middle of the shaft, and on the two ends... The wider washers/spacers go on the two middle....
So from one end of the shaft, it goes; short-wide-short-wide-short....
I would replace them, as I see many of them stretched from over torque. There was an error in the service manual for many years on the torque spec of 30 ft * lb, when it should be 200 - 225 in * lb... 30 ft*lb will stretch and break the bolts.
I can post pictures if you need, just let me know...
You can get a new set for $25:
Retainer and Bolt Package
Forget how it works, but they do that with the back one on a slanty...yep yep - got that figured - what I am getting at is that I have read/heard that there are different bolts - two of the 10 for the rocker shafts are thinner to allow oil to run up and into the rocker shafts...
No, there is an oil passage in the head next to the bolt for the oiling. the bolts are all the same...
ok cool - I have had to take the upper 1/2 apart trying to diagnose an issue.. information is king.. thanksNo, there is an oil passage in the head next to the bolt for the oiling. the bolts are all the same...
I read and went with 300 inch pounds - 25 foot pounds..
seemed a little much in an aluminum head but that spec came right from Edlebrock so...Just multiply foot pounds by 12 to get inch pounds...
Yes;
300 / 12 = 25
that's all long ago done - I was just concerned because of what I read about the shaft boltsI would be very carefull torquing to that spec... go slow and feel for it stretching and stop before you stretch the bolts too much...
Is their spec for a grade 5 or grade 8 bolt??? I would ask more questions before going that high...
Good, I dug up the leaking water pipe. Liked to have killed me!hey ya Tim - how's it going?
Back has been better, but the hard part is done. Freakin pipe was 6ft deep. I originally buried it 3 feet, then when I had my pool built, they put 3 more feet of soil over that!seems you survived it - how's the back?
yep 97 degrees yesterday, dug it up anyway.that's where you disappeared to yesterday...
yahoo... I am surprised as heck that you went for it - oh wait, you're a Mopar guy - gotta save the $$ for the really important things...Back has been better, but the hard part is done. Freakin pipe was 6ft deep. I originally buried it 3 feet, then when I had my pool built, they put 3 more feet of soil over that!
True words.yahoo... I am surprised as heck that you went for it - oh wait, you're a Mopar guy - gotta save the $$ for the really important things...
oh snap - that would have prompted a "F-it - it'll still be there tomorrow" from me!! LOLyep 97 degrees yesterday, dug it up anyway.
