It does have the bell housingHad one. See if it has the trunk aka the built in bellhousing. If so, that’s heavy sucker
Ignore the fun police , the rest of us do hahaI was under the impression that this was a general discussion thread.
Was I wrong?
Thats a pain, there are adapters though. or can be machined off, still a pain.It does have the bell housing
Heavy and currently impossible to get an adapter for the trans. There’s two company’s that make them and both have been out of stock for 2 years. It’s why I sold mineIt does have the bell housing
John, should have gone to this auction. This Charger went cheap - relative - and is super cool!
Definitely explains why they called the hemi the elephant. My engine hoist that picks up Cummins all day long, struggled with the off balanced weight of the 354 hemiThats a pain, there are adapters though. or can be machined off, still a pain.
It went for $10-12K ish IIRC. With NASCAR and ARCA history.Ok that’s cool. That would have worked! I even tried to snag an old Jeep but that fell thru. This 360 is burning a hole in my pocket!
I had one for a while also. Built a 6x2 log intake for it. Had a matched set of 6 Holley 94s for it. Would have been pretty cool in the hot rodDefinitely explains why they called the hemi the elephant. My engine hoist that picks up Cummins all day long, struggled with the off balanced weight of the 354 hemi
That 1960 Corvette I owned for 40 years was 525 HP Stroker and car only 2900lbs.....Imo 500 hp on street not that much. My 408 is close and very driveable when trans stays togather...
My goodness that had to be a great driver, fun and stealthy.That 1960 Corvette I owned for 40 years was 525 HP Stroker and car only 2900lbs.....
Sure would have.I had one for a while also. Built a 6x2 log intake for it. Had a matched set of 6 Holley 94s for it. Would have been pretty cool in the hot rod
Yeah but that’s only 100 miles at a time hahaImo 500 hp on street not that much. My 408 is close and very driveable when trans stays togather...
Although the Fart Can Mafia use all 167hp all the time around hereIn a straight line I can see it.
I’m not talking about a straight line, or just normal cruising around town.
Heck the sick week and drag and drive guys prove thousands of horsepower cars can be driven on the street.
I bet 90% of the drivers that build cars over 300 hp can’t actually use it to its potential on the street.
About the same weight as early A bodyThat 1960 Corvette I owned for 40 years was 525 HP Stroker and car only 2900lbs.....
Agree. No way to actually get that power to the ground in my 66. First off 14 inch rubber leaves much to be desired in traction dept.In a straight line I can see it.
My Cuda is just a touch over 600 and I drive it on the street! Why not?That 1960 Corvette I owned for 40 years was 525 HP Stroker and car only 2900lbs.....
Just curious , what is the HP in the Demon ?My Cuda is just a touch over 600 and I drive it on the street! Why not?
I would have to dig out the dyno sheets but I want to say right around 510? But the motor is just bolt ons and tuning in essence I just let the thing breathe. When I say bolt ons that includes manifold etc. I left the cam OEM. Everything I read said a simple cam change really opens it up but frankly much like @TrailBeast original post I simply did not see the need for anymore HP on a daily driver. I can literally take off in 3rd gear if I feather the gas a bit. And with the OD I am barely squirting oil at 70hp! It drives great, just purrs. Pix on the dyno, and during segment on TV series.Just curious , what is the HP in the Demon ?
My 73 weighs in at 2,900. with low fuel in the tank. And traction with a 408? None. LOLAbout the same weight as early A body
