Stop in for a cup of coffee
Header gasket material ordered √
Hood adjustment bumpers √
License plate screw set √
Parking light lenses √
Quarter window seals √
Cowl drain flap √
Oval firewall plug √
Stainless door lock knobs √
Twin post mirror gasket √
It's fun to go shopping !
I might try bigger screws to mount my outside mirror. If that plan doesn't work out I may try something like this? The button's should be flush enough. (I would hope)
Hey gang.
Well, I got the car started... needs a bit of adjustment, but otherwise, turn-key and vroom. Oil pressure is a little high ??
Transmission is shifting correctly on jack stands.... couple of minor leaks to attend to, one at the cooler line and the purgatory at the thermostat housing.
Apparently I boogered up the Tach wiring... it's not working
Awesome!! Congratulations!
So what is the problem with the mirror switch. I missed it
I unscrewed the broken mirror (not OEM) and found 4 holes. The 2 holes I can reuse are too big for the screws provided so I will try some larger screws. . The gasket won't cover the outer holes. I might just seal them with silicone for now. Or may be a small plastic plug.
The factory mirrors on those cars sucked so bad it is very very common to see later model mirrors on them. Mine has a pair of A body dart sport mirrors on it
I’d try some of that 3M body tape, the mirror body will likely cover up that hole.
  • Tnisesm 135Pcs 8 Sizes Nylon Plastic Hole Plugs Black 1/4" 5/16" 3/8" 1/2" 5/8" 3/4" 7/8" 1" Round Drill Hole, Furniture Cabinet Insert End Caps Industrial Hardware Biscuits & Plugs
Roll over image to zoom in
Tnisesm 135Pcs 8 Sizes Nylon Plastic Hole Plugs Black 1/4" 5/16" 3/8" 1/2" 5/8" 3/4" 7/8" 1" Round Drill Hole, Furniture Cabinet Insert End Caps Industrial Hardware Biscuits & Plugs​
Here ya go Mike fill the plug with j b push it in the hole and screw down the mirror.
The kit is 10 bucks on Amazon
