Stop in for a cup of coffee
I bought a set of rear wheel well liners from Rough Country recently - they arrived today - took a little longer than they said to get them in, but boy did they clean up the trucks' look - - no pics yet because as soon as I got done we hopped on the scooter and took off - but, pics or not - it did happen :thumbsup:
I like the liners.. my latest truck came with them. Tbey are awesome. Hose 'em off, they look like new, even 40K miles later
yeah, I thought it looked a little odd without them at stock height - once I lifted it - the look was way off - it really needed them
Have fun with that... I am still fussin with my driver door leaking water. want to rework the inner plastic today. Probably leave the inner panel off this time and go sit in it and watch for leaks tomorrow if we get the rain they are calling for. Also need to get under the Magnum and check for a couple 'oil' leaks.
well, got the Duster door sealed up and back together. Then got the pressure washer out. cleaned up the trunk carpet for the Neon. The spare lays in a carpeted well, Was a lot of rust in the carpet. After press washing out as much as I could it was still stained bad. Used Zep purple cleaner and it took out almost all of it. Took the under bumper and engine splash shields off the front of the Magnum and cleaned up all the oil I could. not seeing any active leaks. Thinking it may be from when I had trans fluid changed. The new seal on right side of rear is leaking, so hopefully that is a warranty job. Last but not least I needed to change left brake bulb. should have been an EZ job... popped a cover off inside. Did not realize at first there was a nut there to release the tail assembly. Started to unscrew panels. Looked again and realized not necessary, So I take two other fasteners out and loosen the nut. Crap. :BangHead: Where did it go? :wtf:. Ended up tearing a whole mess of stuff out to get better access. The thing was WAY down between inner and outer metal. About an hour into the job I was able to get a grabber tool on it and lift it out. Went up to AZ and got bulbs. Install. Reassemble. Only a couple hours to change one side of tail light bulbs....
Well good morning coffee crew, lets see what this day will bring
Let's hope good things for all.
Amen brother, in case some of our coffee crew did not see this :( a fellow member's daughter and a member Nella has been in the hospital for weeks now and bills are climbing and many days of lost work, just a heads up but a part of this sites family for many years are in need :( here is the thread FABO Member Could Use Our Help
Hey guys and gals.
If you haven't heard about what happened in New York, New Jersey and Minnesota, I'm sure you will soon. We got a briefing on what appears to now be public information. In short, if you live in any population center, be aware. IEDs were used yesterday in multiple locations.
Be safe everyone.
Good Morning Memi !! Yup , I saw that yesterday. Don't know if I have any parts to contribute, but I can send funds to a Paypal Acct.
They are some special folks Mitch, here I am with Tony fields and Nella (in the wheel chair) her father @cosgig and brother..
