Morning all. Yes as I said a few weeks ago it is only the beginning....
Thoughts sent Meme.
Thoughts sent Meme.
They are some special folks Mitch, here I am with Tony fields and Nella (in the wheel chair) her father @cosgig and brother..
kEITH YOU BEEN CORRUPTED FROM kpax ALSO?
What happened in MN?[/QUOTE said:Black Lives Matter ??
you confuse easily and it takes hours to change a brake light bulb...
Umm, I don't think so. lol Should I get myself checked? What are the symptoms?
well, not usually on the confusion... but you got me on the bulb.you confuse easily and it takes hours to change a bulb...
that's because you've only done a little - you need more and moreMorning folks. Coffee ain't working yet!
NoYour little buddy turns blue?
bunch of people stabbed in a mallWhat happened in MN?
a blue member!!Your little buddy turns blue?
Cheers, and welcome to the confusion.Good Morning Y'all..... Going to be a Hot one here in SO-CAL.. Headed up to 100*... Get out and work on those Mopars.... Coffee first... Cheers
The little's gettin more and more... maybe it'll work..that's because you've only done a little - you need more and more
g'morning!Good Morning Y'all..... Going to be a Hot one here in SO-CAL.. Headed up to 100*... Get out and work on those Mopars.... Coffee first... Cheers
there's a one liner in there... not enough coffee here yet either thoughThe little's gettin more and more... maybe it'll work..
Never got anything from them. If I can plan ahead, order from Advance, get online discount and go pick up down the street. Or if I need it right away AZ is here too. Multiple stores of both plus PEp Boys, NAPA and more within a few miles.Got a rock order yesterday, I have to stop ordering from them getting the same magnets!
