Then put Chris in it!
to a point yes, both the NHRA and SCCA rule book have certain rules for the cages that really limit what one can do. especially for unibody cars. After researching the rules, there's very few areas that are open to variations for my particular class. Namely the door bars and rear support bars.Engineer should get you a LIGHT and STRONG roll cage, Emphasis on the light. Anyone can weld together a strong cage, but how much does it weigh?
hahaHave her write it down and sign it then you are covered.
plus, the goal for this car is to be that of a stock A body small block car. With the amount of weight savings i already have done(roughly 417 lbs) i should be able to come in around that mark. i'm estimating about 200-250 lbs in the cage.Engineer should get you a LIGHT and STRONG roll cage, Emphasis on the light. Anyone can weld together a strong cage, but how much does it weigh?
I hope with all that attention to weight, you are also figuring out how to rebalance the car to get closer to a 50/50 weight balance.plus, the goal for this car is to be that of a stock A body small block car. With the amount of weight savings i already have done(roughly 417 lbs) i should be able to come in around that mark. i'm estimating about 200-250 lbs in the cage.
Nope. You are doomed. She has thought of one possible way for you to do the 'right' thing. It is highly unlikely that you will figure out what that is. 9 out of 10, it ain't what she says either.Have her write it down and sign it then you are covered.
Yes actually I have, most of the weight is actually coming out of the front of the car. The only thing that's really being lightened in the rear half is maybe a couple pounds in the leaf to 4 link conversion.I hope with all that attention to weight, you are also figuring out how to rebalance the car to get closer to a 50/50 weight balance.
All the stuff you've talked about so far removes the weight from the rear half of the car and with a heavy big block up front...your balance is going in the wrong direction.
AgreedNope. You are doomed. She has thought of one possible way for you to do the 'right' thing. It is highly unlikely that you will figure out what that is. 9 out of 10, it ain't what she says either.
That's an easy cover. Buy something and then only give it to her if she seems disappointed that you didn't get anything (or gives you something). If you don't use it, it's an emergency 'gift' for another occasion.my wife trying to trap me. Says she thinks Valentine's Day is a waste and highly over rated and that she doesnt wanna celebrate it...
Oh, and if you actually do what she wanted....she could change her mind.Nope. You are doomed. She has thought of one possible way for you to do the 'right' thing. It is highly unlikely that you will figure out what that is. 9 out of 10, it ain't what she says either.
WomenOh, and if you actually do what she wanted....she could change her mind.
Sounds good. I assume you are also looking at lowering the center of gravity by sinking the battery and fuel cell halfway down through the trunk pan to match the center of the mass of the engine that sits at that height up front. 50/50 also means a matching center of gravity height front and back.Yes actually I have, most of the weight is actually coming out of the front of the car. The only thing that's really being lightened in the rear half is maybe a couple pounds in the leaf to 4 link conversion.
I've got a few tricks up my sleeve as well, battery to rear most corner, all steel in the back including bumper and bracket, front bumper will be fiberglass along with the hood, no hood hinges, or latch, the 50 lbs of power steering is gone, replaced with a 6 lb power rack, tubular front suspension and disc brakes, roughly 100 lbs there, engine is pretty much all aluminum top end, should end up very close to that of a stock 340 weight, no torsion bars, them heavy things replaced by lighter coil springs, fiberglass dash.
If my math is right, total balance should be very close to 50/50. Right now I'm estimating it at 52/48. With 4 corner coil overs, I should be able to adjust that by corner weight and get very very close.
Actually yes. The class I'll most likely end up in requires the fuel cell to be mounted flush or below with a 1/8 thick plate bolted to the frame covering it.Sounds good. I assume you are also looking at lowering the center of gravity by sinking the battery and fuel cell halfway down through the trunk pan to match the center of the mass of the engine that sits at that height up front. 50/50 also means a matching center of gravity height front and back.
It's why my SRT uses a battery mounted below the deck in the trunk and twin self-leveling saddle fuel tanks underneath the rear seats just in front of the rear axle.
Good call. That's where (and why) my battery sits in the SRT. It's a big battery, about the size of two standard batteries from my GTS. Weighs about as much too.Actually yes. The class I'll most likely end up in requires the fuel cell to be mounted flush or below with a 1/8 thick plate bolted to the frame covering it.
As for the batteries I have a trick for that too.
You know the area between the passenger side frame and the quarter panel where the trunk floor extensions go? Well, some measuring shows that I can fit two batteries there? Tops flush with the trunk floor , thus not only offsetting my front to rear weight but helping to offset the driver weight some as well
Nothing like a pile of parts to motivate you!Evening!
All the parts I have ordered have come. Now to get mobile again.
I think I have to run a foam filled one. But I'm looking at running dual 15 gallon onesGood call. That's where (and why) my battery sits in the SRT. It's a big battery, about the size of two standard batteries from my GTS. Weighs about as much too.
Just get a baffled fuel cell to prevent fuel suddenly sloshing to one side and it sounds like you've got it.
Chris, that car is going to be awesome when you get it all done!I think I have to run a foam filled one. But I'm looking at running dual 15 gallon ones
If... you're assuming my wife doesn't kill me over it first lol thanks though.No doubt! Now just to hope for a trouble free year with the car.
I know I'm itching to get started on my wheel/tire and suspension upgrades. I'm intentionally not going to order the new torsion bars until after the remaining 2 wheels get here just so that I'm not staring at a pile of parts screaming at me get installed. First I will get the wheels and tires mounted and balanced, rears installed and then tackle the torsion bars with the new wheels ready to go on it when it's done.No doubt! Now just to hope for a trouble free year with the car.
I caught a redhead in one of those once...
