MomsDuster
Yeah, well there isn't much better than getting over the funk to make you appreciate feeling good.
yea - not ready to go jogging around the block - but I am ready to rock and roll!Yeah, well there isn't much better than getting over the funk to make you appreciate feeling good.
Atta boy!yea - not ready to go jogging around the block - but I am ready to rock and roll!
I haven't felt good enough to jog around the room much less the block in years!Atta boy!
I am TRYING to get back to at least doing some distance walking - but jogging??? yeah, no.I haven't felt good enough to jog around the room much less the block in years!
i'd like that M113Daddy posted some of his work a couple days ago about Humvees. Heres a few shots of some miitary equipment at a Freightliner dealer on my route. The owner collects, restores, and resells.View attachment 1715020702 View attachment 1715020703 View attachment 1715020704 View attachment 1715020705 View attachment 1715020706 View attachment 1715020707 View attachment 1715020708 View attachment 1715020709
ouch, i tore my ACL in 2008I've been dealing with a bad knee since 2008. Doc now says I need a new knee. This should be interesting (workers comp) woohoo!
You said Blower !!!heater blower motor??? whasssat?
I always liked them... But I'd have to have a 1st gen....if I had a Humvee .....the earth's population of raccoons would be in grave danger
No feel good!ouch, i tore my ACL in 2008
Were you running ??ouch, i tore my ACL in 2008
Indeed !!
trust me, the raccoons would then have an advantage,if I had a Humvee .....the earth's population of raccoons would be in grave danger
Humvees are absolute junk..... transmissions and axle problems constantly. and good luck starting one below 40 degreesI always liked them... But I'd have to have a 1st gen....
Were you running ??
Indeed !!
Maybe you should go with the Hoppy 8 1/4 option ?? Plenty available..I still need to decide what rear end to use in Princess Valiant ....I was thinking of using a 7 1/4 at first but parts for those seem to be no where around and to get a sure grip $$$
I need to break out the tape measure and see what is at the pick a part yard.
It doesn't need to be that fancy of a rear end ...just maybe a bit stronger than a 7 1/4 with a good gear selection and readily available parts since this is gong behind a slant six
Gott Chait actually has an A-body 8 1/4 in it now that some previous owner put in but I was going to pull it and put in the 75 dart behind a 360/833 OD ....I was thinking it's too much overkill for a slant. Unless I found another one for the dart
Too bad you weren't closer I know where an 8.25 suregip isI still need to decide what rear end to use in Princess Valiant ....I was thinking of using a 7 1/4 at first but parts for those seem to be no where around and to get a sure grip $$$
