I'm borrowing a trailer this time, so not an issue...I think Chris's point was to get an enclosed trailer. But if it's not designed to put a car in...Rent round trip and return it where you got it... It's more reasonable...
Are you talking cars or body parts here???
And maybe again as soon as you get home.Just wash it down good when you get there.
Enclosed box truck lolI'm borrowing a trailer this time, so not an issue...I think Chris's point was to get an enclosed trailer. But if it's not designed to put a car in...
OK, I know what you are saying, but I think I will go with my original plan. I'll have a slight line about 3/8" in. Paint will get in that far without opening door. I'd rather that so I can focus on doing the outside. If I start opening and closing doors, I am asking for disaster. Should be close match, I painted the jambs last year.At the first angle. Like the quarter flange in the door jamb, tape it at the back edge. Across the rocker below the door there is really no good way because you need to keep the paint line inside the door with it closed. I'll Take a few pics later so you can see what I'm talking about.
It can carry in pretty far.OK, I know what you are saying, but I think I will go with my original plan. I'll have a slight line about 3/8" in. Paint will get in that far without opening door. I'd rather that so I can focus on doing the outside. If I start opening and closing doors, I am asking for disaster. Should be close match, I painted the jambs last year.
What do you think of Ray's idea to just let the overspray hit it -no tape?
??Man Trump just really made the world angry as hell hahaha go Trump!!
and look OK, or not so much?It can carry in pretty far.
He pulled us out of the Paris emissions deal
Horsepower is never exactly half of the torque. For that to be true, the equation would have to be H= T / 2 regardless of the rpmExplain something to me cuz I'm stoopid!!
If H = T * RPM/5252
Given a torque curve for an engine, one could plot the HP throughout the rpm range...
The math says that torque and horsepower are always equal at 5252 rpm.
And horsepower is always exactly half of torque at 2626 rpm..
So why do I see HP/Torque curves posted that don't follow the laws? Am I missing something?
For example.Explain something to me cuz I'm stoopid!!
If H = T * RPM/5252
I get that the 5252 is a constant (and almost understand where it comes from!)... If you plug in 2626 as rpm with a 5252 divisor, you will get 1/2... Which would always equate to HP being half of Torque at 2626 RPM...For example.
450 ft lbs @ 4000 rpms
H = 450 * 4000 / 5252
H = 1,800,000 / 5252
H= 342.8
Where you're getting confused is the 5252. That's not the RPM, that's the fixed divisor
So while your rpm can be 2000 or 3000 or 4000, the 5252 stays constant in the formula, the rest of the numbers will change
For that particular RPM, in theory, yes. But then you get into dyno accuracy etc. most dynos measure rpm by hundred or at the lowest 10 rpm. Which throws that offI get that the 5252 is a constant (and almost understand where it comes from!)... If you plug in 2626 as rpm with a 5252 divisor, you will get 1/2... Which would always equate to HP being half of Torque at 2626 RPM...
It can look ok, but if you shoot a sealer it can carry a little deeper and you'll see it more.and look OK, or not so much?
It's because you aren't using the equation correctly. To determine HP you need to know the torque at a given RPM and then apply the equation to get the HP at that RPM.Explain something to me cuz I'm stoopid!!
If H = T * RPM/5252
No sealer. Prob 3coats of SS.It can look ok, but if you shoot a sealer it can carry a little deeper and you'll see it more.
OK.. i get that on a chassis dyno there are torque multiplication factors from gearing and parasitic losses...... I'm just looking at engine dyno stuff (which seem to use about 3k as their bottom rpm range). But if any engine makes 300 lb-ft of torque at 2626 rpm, horsepower is half that? Math says so... and if it makes 400 T, HP is 200???? Just trying to wrap my head around it. Seems the 'gap' between HP and torque curves should look the same (or similar) for any engine (granted it's torque producing properties could make the slopes of the lines radically different, but the numeric 'gap' should remain the same, percentagewise).. i may be high tho...It's because you aren't using the equation correctly. To determine HP you need to know the torque at a given RPM and then apply the equation to get the HP at that RPM.
Torque at any given rpm does not meant that you can use the equation to calculate the entire torque range unless it is a completely flat or linear curve and you already know what the slope is. The short answer is that the equation is only used to calculate one value from the other (HP or Tq) at any given RPM, not across a range
Sounds like a Good time.Out at or local Black Cap Brewery. Enjoying a couple cold ones with my daughter who turned 21 this week
Well, if you look at this curve you see that HP and Tq intercept at 5252 and HP is exactly 1/2 of Tq at 2626 but the rest of the curve relationship seems to fall apart...OK.. i get that on a chassis dyno there are torque multiplication factors from gearing and parasitic losses...... I'm just looking at engine dyno stuff (which seem to use about 3k as their bottom rpm range). But if any engine makes 300 lb-ft of torque at 2626 rpm, horsepower is half that? Math says so... and if it makes 400 T, HP is 200???? Just trying to wrap my head around it. Seems the 'gap' between HP and torque curves should look the same (or similar) for any engine (granted it's torque producing properties could make the slopes of the lines radically different, but the numeric 'gap' should remain the same, percentagewise).. i may be high tho...
Very cool!Out at or local Black Cap Brewery. Enjoying a couple cold ones with my daughter who turned 21 this week
Hey! Where'd everybody go??
