Ok on another note changed out the parts washer fluid the other day, had at least a 1" of muck in it, did find all the small clips I have been missing for a while though!
huh - this whole cleaning up thing seems to be working for youOk on another note changed out the parts washer fluid the other day, had at least a 1" of muck in it, did find all the small clips I have been missing for a while though!
I said AFTER the fun part. I had a crazy Gal I was hittin'! She left when not needed! She came around when the Fun part was to start!!
And she was HOT!!!Perfectly trained...
Whenever I clean anything to do with my cars, I always find stuff I "lost"huh - this whole cleaning up thing seems to be working for you
it's when you find stuff other people have lost that you need to worry!! LOLWhenever I clean anything to do with my cars, I always find stuff I "lost"
I was using oil eater in it the stuff really works well, could not find any local so I am trying purple power 50/50 mix seems ok so far on the distributors. Might as well get a few ready to run. Hey any one know the name of the grommet/boot that the points wire uses? I actually need some, wires by themselves are 10-40 ea nos no way I am doing that.Is muck easier or worse to clean than gunk???
this type of "grommet"?
only because your thumb still isn't working right...there's so much nudity on tv, I just sit there shaking my fist....
Looked, I vave been re using them but getting the wire out then using a drill to get the wire cover out sucks, no idea of the name either.No idea.. Rock Auto???
They are available aftermarket, or at least they were. Called Primary Lead, if I remember correctly. We use to sell them in Filko and Standard Ignition.I was using oil eater in it the stuff really works well, could not find any local so I am trying purple power 50/50 mix seems ok so far on the distributors. Might as well get a few ready to run. Hey any one know the name of the grommet/boot that the points wire uses? I actually need some, wires by themselves are 10-40 ea nos no way I am doing that.
the little rubber piece might be a dust bootthis type of "grommet"?
