Stop in for a cup of coffee
so the question begs - what is the tensile strength of that particular steel... and will it hold up to a 40 ton press..?
It's not the tensile strength that counts here, it's the compressive strength... (tensile is pulling outward - compressive is pressing inward)
isn't spring steel, in it's own way, actually more brittle and susceptible to side impacts?
It has some ductile properties also, that's how the torsion works - it bends in the elastic range where it is capable of bending back to it's original position...
ok- so if you cut an inch out of it and crimp them back together with a sleeve - won't the sleeve itself be the eventual failure point?
My Canadian friend wanted to go clubbing...
But we couldn't find any seals...
Possibly...
You can get more holding power with longer sleeves for more material engagement... Ie. 1 1/2" vs 1"....
I saw this one the way home and just had to grab a pic...
Walk-ins welcome?? I don't need a car? What are you going to do, put tires on my ankles and change the oil in my knees?
