Stop in for a cup of coffee
I bet the rod would slip in the sleeve sooner or later..
Not if crimped properly... I used to work at an automotive cable company and we crimped fittings on strand and conduit all the time... If crimped properly you could get 150 - 250 lb pull off strength on some crimps...
well - best case will be finding them used and good to go... if not, i really would try to find a good welding shop and run it by them
I would recommend he stops in the welding shop instead of running by it... :poke:
Just stopped by. Wouldn't the rod spin inside of the crimp because of the torsional twist?
No a good hexagonal crimp will hold pretty tight if he has enough wall thickness on the sleeve and a good crimp...
General rule of thumb is 75% - 85% of original diameter for crimp....
Use a good inertia or hydraulic crimp press...
might work if you were to crimp the sleeve onto the rod and then spot weld it in two spots on either end...
Or the roll pin trick. You might be able to grind flats on both sides of each rod for the crimp to bite to.
Have you tried to pull an end fitting of a trans cable conduit??? It won't spin or pull if crimped properly... Try it...
oh - I get it - I'm just thinking that there is quite a bit of torsion on those rods and given enough time (YEARS) that it would eventually fail.. ???
You are all over-thinking this, use a good crimp...
30 - 50 ton press, thick wall on the sleeve, and crimp to 75% - 85% of sleeve od to across flats of hex...
I did the pull testing and design verification testing for developing the transmission cables for Saturn and the Chrysler JA Cirrus/Stratus...
We cycled the Saturn cables with 160 lb of force on them for over 100,000 cycles on our test fixture.... Including some of that testing at - 20° F for part of those cycles...
A good crimp will hold...
well - where the heck were ya while poor Tim was kicking this puppy around!! - - - oh yea, SLEEPING... :poke::poke::poke:
A good crimp will not move... It will take many years for it to fail if done properly...
It should last longer than most of us will live... (Then it's someone else's problem after we die...)
I'm so good, I can do this in my sleep.... (I'm still sleeping - sleep typing, like sleep walking....)
just to throw some fodder on it - any chance the crimping itself will be too much for the rod? maybe crack/split it and cause premature failure?
