GeorgeH
I was looking for the things they bolt to. lolHey @GeorgeH You still looking for these?
MOPAR NOS FENDER TURN INDICATOR LOT / DODGE PLYMOUTH CHRYSLER IMPERIAL RAM
No that is what is on there now! Putting on VN2157765 Classic Torq Thrust II 17x7 5x4.5 4.0That's what you ordered? don't think I have ever seen them. Pretty cool. But very different. Most likely will look great, but think I would have requested a DDaddy virtual fit test before pulling the trigger...
that's a big change...and 17's? So lower profile tires?No that is what is on there now! Putting on VN2157765 Classic Torq Thrust II 17x7 5x4.5 4.0
The tires I have in mind will actually be taller! 50 series tire 275/50 R17that's a big change...and 17's? So lower profile tires?
Nitto NT450 | TireBuyer 27.8 tallThe tires I have in mind will actually be taller! 50 series tire 275/50 R17
what did you have on?The tires I have in mind will actually be taller! 50 series tire 275/50 R17
Rear P245 /60 R15 Front 195/65R15what did you have on?
That's a lot of tire...Rear P245 /60 R15 Front 195/65R15
That's all you use in a year?!?!What do you do with 365 used condoms???
Melt them down and call it a good year....
LOL Know how to reuse a condom?What do you do with 365 used condoms???
turn it inside out and shake the F**K out of it!
27.8 diameter looks like a great size for 3.91 gears..That's a lot of tire...
Tire Size Comparison
Funny you would say that, that is the gears in my 69.27.8 diameter looks like a great size for 3.91 gears..
HiYeah, show me a married man that has....
Well power is back. Ok heres a murphy's law in effect, that nos 440 electronic retard vac advance I sold a few weeks ago, well I need one now for a dist I got to do a proper restoration on! I do have a similar one but one up on the part number, no Idea if it is the same.
The scrapper is becoming my best buddy these days.
My timing is off too because scrap is so low right now, only getting 25- 30 bucks a truck load.
I don't really care, I am not doing it for the money but more the clean up.....I should have done this long time ago
27.8 diameter looks like a great size..
