Ddaddy
I'm changing the World... one pixel at a time!
Whoops, the sky just got wicked dark and the wind is kicking up. Time to boogie out of work and see if I can beat the front and get home before all hell breaks loose!
Sure! I'd be happy to have them.Dave still want old boxes for the shop?
On a stock suspension, yeahSo 245? Is as wide as I can go?
Yep.So 245? Is as wide as I can go?
That size in a 17 is almost exactly the same as what I have now.So 245? Is as wide as I can go?
You can play with the rim specs and tire height to get widerThat size in a 17 is almost exactly the same as what I have now.
I already ordered the wheels. 4 inch backspacing. That size tire is still ok.You can play with the rim specs and tire height to get wider
See, Dave know shi..stuff!Post #4 has them on a Duster, that's why they can use the 275 width. No way will they fit on a '69 Dart. 245 is about as big as you can go without modifying the spring offset and then you will need a different back spacing on the rim. In rare cases, a 255 will squeeze in there but only if you get lucky on the factory sloppy clearances.
This is why I went with the gerst kit since I wanna road race. I can fit a 285 up front and a 295 in the rearSee, Dave know shi..stuff!
Makes sense. I wanted same on all 4 so went with 215 70 14s. about as big as I can go up front. But still kinda get lost in them wide Duster quarters.
makes for an exciting ride homeWell, I made it home...but I didn't beat the front. I got pounded by heavy rain, wind and lightning the entire length of 476. I thought a semi was going to blow over a few cars in front of me. I saw daylight under the right side trailer wheels.
Don't rely solely on the 255 width. You need to check the centering of each hub on each side and then verify that you have the clearance based on the wheel offset. For example, I can fit a 255 on the passenger side but it won't fit on the driver's side. These cars have a lot of slop in the clearances and you can't be certain they are the same on each side or that the axle sits in the same centerline on each side.From what i have measured the 255 will fit.
Any one have a 70 or 71 FSM that has a 440 dist spec to see what that thing actually does and maybe how to test it? Mymopar is not downloading
What I have under their now has plenty of room. Can get finger between all sides.Don't rely solely on the 255 width. You need to check the centering of each hub on each side and then verify that you have the clearance based on the wheel offset. For example, I can fit a 255 on the passenger side but it won't fit on the driver's side. These cars have a lot of slop in the clearances and you can't be certain they are the same on each side or that the axle sits in the same centerline on each side.
Mike is your car mini tubbed?
What is the offset of those wheels? Also lay a board edge across the face of the wheel/tire and the against the bottom of fender lip and put a mark on it where the inside edge of the fender lip is. If you do this on both sides, you will be able to get a measurement of the true clearance for the section width of the tire.What I have under their now has plenty of room. Can get finger between all sides.
Can get finger between her sides.
It took a hour to download, shows a pic of it but no testing or explanation of what it does.I got one if you haven't found the info yet...
Usually they are pretty cool!Ugh anyone know much about the ac systems on the 07 durangos
Some. It's not very different than the system on my '06 Charger. What's the issue?Ugh anyone know much about the ac systems on the 07 durangos
