testies, testies...
One... Two... three????
HOT TANK POWDER For AluminumAny one know how to say hot tank aluminum to make it factory fresh?
one little two little three little testies............
there is always one that is bigger - it's a matter of degreeWhat if one's bigger???
What do you call a Chevy at the top of a hill?there is always one that is bigger - it's a matter of degree
do tellWhat do you call a Chevy at the top of a hill?
a Miracledo tell
a Miracle
maybe lolsee!!? miracles DO happen!
Pretty good I spent the day yesterday getting to know it remove the shifter lubricated it adjusted the rods it's a lot better now I can drive it I still might put the Hurst shifter in itmorning how's the cuda?
2000lbs. is a ton. The designation is about capacities..Hey, what's the deal with the ton designations on trucks?
And what IS a ton according to you crazy standard/imperial unit dorks?
its an arbitrary numberso ya gotta wonder why a 2500 is a 3/4 ton truck...
... which is sorta what I was getting at ...so ya gotta wonder why a 2500 is a 3/4 ton truck...
simply an arbitrary number now adays. However, when the thing started it was to tie it to its total towing capacity counting its own weight.... which is sorta what I was getting at ...
IE:
1500= Towing + GVWR (gross vehicle weight rating) =15,000 pound
2500= Towing + GWVR =25,000 pound
3500=Towing + GWVR = 35,000 pound
Same thing, its a hold over from the old days. a few decades ago, that was the carrying capacity of the truck before the suspension would be fully maxed out.A-HA! Finally an explanation!
But how does the 3/4-ton designation fit into this?
