When will Mike 3 be back, this is for him
that was my worry, theres not a lot of metal there to cut even. Radiator is rated to cool 800+ HP. I figured being roughly 55% of that in the 440, plus the high flow water pump, dual fans and I should be able to drive rush hour traffic in LA just fine on a hot day.I would put 3/8 shims between the radiator support and the radiator, this will let air pass , I don't think I would do any cutting for 2"
No, you don't want to to that, because the air will then go around the radiator instead of through it...
Question..... I was doing some measuring on the dart yesterday.... the opening for the radiator is only 22.5 inches wide. I'm gonna be running a 26 inch, 4 core radiator to keep the big block cool. My question is, should I try to cut the opening larger by 2 inches on each side?
Hay !! If I know you, you like it that wayMorning guys. Busy week this week. Family vacation this week and Mopar Nats next week.
Did you send her a note back to be sure she knew when your birthday is?A lady friend sent this to me , she said it's at the dealership and I should go buy it.
morningDid you send her a note back to be sure she knew when your birthday is?
Good Morning
Morning, aint no body here today'Morning all....
No one at "work" I guess...Morning, aint no body here today
i am but i was told i was getting too much done and to slow down a tad, so im designing something cool and unique for my dartNo one at "work" I guess...
