Hey... Im still here... But I guess Im working...I mean, I am out in the shop....Does that count ????I am out also later!
Yes, yes it does! lolHey... Im still here... But I guess Im working...I mean, I am out in the shop....Does that count ????
Hey... I got no side work today... I'll be assembling the rest of the 383 engine ...Yes, yes it does! lol
Nice That paint dried ok ?Hey... I got no side work today... I'll be assembling the rest of the 383 engine ...
Yup... Hard as Hillary's Heart !!!!!!!!!!Nice That paint dried ok ?
That's always exciting. I talked to my friend that bought my stroker. He got his cam and is looking for heads. He is getting so pumped!Hey... I got no side work today... I'll be assembling the rest of the 383 engine ...
Good morning. How old are you Jeff?Good Morning All!
Psh I'm only 30....I'm just a baby, 62.
Am I not old enough to play?
Dang youngins.Psh I'm only 30....
Good deal, always worry a bit when the catalyst has been sittingYup... Hard as Hillary's Heart !!!!!!!!!!
Sure. I'm 62 also.I'm just a baby, 62.
you'll fit right in...I am retarded though!
PO had paper on the car with a credit union that went down. Neglected to follow through and attempt to get a title asWhat's the title issue?
probably have to pay off whatever that balance was is thing though.PO had paper on the car with a credit union that went down. Neglected to follow through and attempt to get a title as
the car still had a financed balance. Now the car is just rotting away, I think I could get it cheap and take up the title
issue with the WSP. Thinking on it------------------DR
im confused, the transmission that came with it is a different size pilot bearing?Ok smart guys, not being sarcastic.
1982 318.
Had manual transmission. Just a pilot bushing.
Looking at transmission,the piolt is much larger than bore in crank.
Crank not stock? Or from older engine? View attachment 1715132057Some awful crude machining there. Now,i’m sure it will fit in my lathe to bore it out some.consider im in the wrong place to just go and buy what i need,so machining crank or torque is my option. I thought the torque would be smaller pilot. It appears not.
Options?
This is a good time to sort it out i think.
Thanks in advance...
Or suggest a thread i should jump into.
WHAT?im confused
Well, I'm not understanding how the engine and transmission, if they were previously mated, would have even gone together if the input shaft is larger than the crankshaft pilot bearing. Which means 1 of a few things. Either they were never together, or the input shaft was too short to ever hit the pilot bearing, or the input shaft was cut because they couldnt get it together.WHAT?
LARD!Parkay!
