zkx14
Duster De-ruster
Yeh, that would be warm water, so you wouldn't have to worry about it freezing.Should've brought some water back from the Caribbean. LOL..............
What are we looking at? Are you lifting your dart?
It's the Watts Link cross member for the Gerst Rear parallel 4 link with Watts link for the dart. I'm re-mocking it up. I had every thing clamped in and ready to be tack welded but I was double checking and noticed the axle was too far back. So took all the clamps out and am remeasuringWhat are we looking at? Are you lifting your dart?
Also I got the trunk open. I'd sprayed it with on blaster yesterday and let it soak over night, opened right up with the key. Then I cleaned it out. 4 feed sacks full of trash... trunk floor as expected is TOAST. But the trunk gutters are perfect. And they must not leak at all as the seal looked good (like its been replaced at one time) and everything was nice and dry with no snow or ice
Rocks ??? I Like Rocks !!! LOL... or is it woks ????Just think. If you every get it done. It will be finished.
Did you figure out Falling Rocks yet.
Psh screw MarkThats a job for Grave Yard Cars....
What reference points do you still have on the body to measure the centerline from? Are the front Spring shackle mounting points still intact?Honestly, I need to find someone who has a factory dart with a 8.75 and find out exactly where the factory centerline is. Nice part is, I can adjust the axle forward or backwards with the links slightly but I want to start with every at factory specs. I've debated moving the axle back an inch or so to give me even more clearance for the bigger tires . Which since I have to have a custom driveshaft cut anyway, isnt a big deal
I was going to go from the front shackle mounting point to the center of the axle. That was the only way I could think to measure it since no 74s came with an 8.75What reference points do you still have on the body to measure the centerline from? Are the front Spring shackle mounting points still intact?
There is no help for meFalling Rocks was a young Indian brave , Who wandered off and was never seen again.
That's why you see the signs by the road to this day. Watch out for falling rocks.
I was just trying to help Chris.
I can measure my GTS tomorrow and give you the numbers.I was going to go from the front shackle mounting point to the center of the axle. That was the only way I could think to measure it since no 74s came with an 8.75
Thanks! No rush though. It can wait till warm weatherI can measure my GTS tomorrow and give you the numbers.
Hmmmm oh KarlI managed to get a cool pic of some orchids in the lobby of the building we had a meeting in today...
