Ben Drinkin
Hey bartender!
Not the good kind! And i haven't had my actual hair cut in months. I should be Clay Matthews-esqe by summer (or Gray Matthews in my case)Did you get a hair cut also???
Just get one of them implantsI would have to bribe Ddaddy to mix me up a boat load of the little blue pills. Couldn't afford them and the trip!
If he would have only known. The damn things went 40.Yeah they are rare these days. Years ago my great grandfather flipped one into the river. This was back in the late 70s, they just left the thing in there from what I was told.
You can buy them cheap at most ports.I would have to bribe Ddaddy to mix me up a boat load of the little blue pills. Couldn't afford them and the trip!
I got a bag of M&Ms... Think they're worth Minneapolis Moline money?If he would have only known. The damn things went 40.
Well that would be a good thingYou can buy them cheap at most ports.
If you were going to put an overdrive of some sort behind my 408 SB, what way would you go?
Along with a lot of other meds.Well that would be a good thing
Only if they are the green ones!I got a bag of M&Ms... Think they're worth Minneapolis Moline money?
Are the green ones pink on the inside?
Not following you. I've been up more then a few hours without my nap.But the Over drive ratio is kind of lacking....
They are all pink inside!Are the green ones pink on the inside?
What's the ratio?But the Over drive ratio is kind of lacking....
With gear vendor the ratio is not the best, so I'm told...Not following you. I've been up more then a few hours without my nap.
What's the ratio?
TORQUEFLITE A727/A904 3-SPEED AUTOMATICWhat's the ratio?
Well like I said I gave 456 gears with tire size it drops it to 373.With gear vendor the ratio is not the best, so I'm told...
