GeorgeH
I do the same way, sometimes the fuel system doesn't prime until you actually have rpm. Hang a tank and a line prime the carb. Spray bottle with gas. If thats a new cam dont keep cranking and cranking though.
Ty, Badass with a Duster!:toothy1:
On a lighter note, since Enterprise upgraded me to that Camaro convertible, I made a couple passes through the Holiday Festival Of Lights last night. It was a nice long drive through hundred of displays...Toyland, Sea Land, The North Pole, Candy Land, Dinosaurs, outer space, Noah's ark, nursery rhymes, lots of Christmas-themed scenes..I went through twice. There was a lot more I didn't partake in, walking trails, a carousel, climbing wall, Santa, marshmallow-roasting, definitely heading back to see everything.
Holy crap George Just got the ladder bars they are great! What was it 20 hours! Thank you so much.
Was there drag racing? Anything is a drag strip if you try hard enough...
Whoa, the are there? I dropped them off at like 2 :30 yesterday
Oh yeah your video is blocked by owner here but plays on you tube.
Yeah the wife went out side and they were next to the door. Almost as fast as paypal!!!!
Oh, ok.
Here's how it's rigged. I think I'll try gravity feeding straight from the jug to the carb tomorrow. With filter.
Just pump the carb a few times to prime the accelerator pump. What is that ethanol? Never seen a green gas can before!!! LMAO
Put some gas in the float bowl also it will help.
Green cans were for unleaded originally but now they're for gasoline. I think diesel cans are black but I'm not sure. I could ask my wife, she works with these things.
I tried pumping the carb but it didn't help. Not enough pressure to fill the carb at all, I think.
I don't care what they say the will help and look OLD SCHOOL COOL as hell.
Im not sure the carb will siphon out of a can that way
Is that a edelbrock carb?
They need a lil cleanup, maybe a spray can detail job
If that carb has sat with fuel in it before it misght have a stuck needle or blocked idle passages.
R̶Duster
Run the hose to the fuel pump and you should be fine. Just drip a bit of gas into the carb about an ounce to get things going till the pump kicks in.
