dukeboy440
speaking of... did you see my thread?When they call here and I make the mistake to pick up, I try to sell them solar power! Click!!![]()
you have had the worst luck with rims/tires imaginableYes....
Ehh, just run it like that. It'll just be like that corner has a ski on it at speed in the rain.Yes....
Would actually make a cool video...for training how a screw compressor works.Ehh, just run it like that. It'll just be like that corner has a ski on it at speed in the rain.![]()
Obviously your climate is better suited for it, but does it fully run your house?Yes Chris I have solar at my place....Whats up?
Running electricYes Chris I have solar at my place....Whats up?
It will run everything and still put enough back on the grid, meter turns backwards, to "store" enough to power to run everything at night, it is called a grid tied system. With a nice credit at the end of the year.Obviously your climate is better suited for it, but does it fully run your house?
The thing is, the panels dont use the light to make power. They use the radiation to make power. And that gets thru the fog. just a small loss.VAFB just installed a pretty sizable solar farm where the off base (unsecured) housing used to be. Normal weather patterns have us covered in fog for 3 months out of the year. Not saying that the Feds are particularly good at cost efficient engineering.
Sweet. Here's the sad part... Indiana just passed a law last year that stops the turning of the meter backwards. So once your production equals your usage, there's no credit or storing it. Also, all solar/wind systems must now have an anti-backfeed system that prevents power from feeding the grid line if the grid loses power. They had several linemen get killed last year due to that they claimed.It will run everything and still put enough back on the grid, meter turns backwards, to "store" enough to power to run everything at night, it is called a grid tied system. With a nice credit at the end of the year.
And our system is 40 panels, all with micro inverters, ground mount, and was about 55 grand. Will take a long time to break even. Am banking on electric rates to keep on going up....It will run everything and still put enough back on the grid, meter turns backwards, to "store" enough to power to run everything at night, it is called a grid tied system. With a nice credit at the end of the year.
fog and clouds are essentially the same thing, water vapor, so would the panels still produce on heavily cloudy days?The thing is, the panels dont use the light to make power. They use the radiation to make power. And that gets thru the fog. just a small loss.
wow! I got quoted a shade under 20 grand yesterday.And our system is 40 panels, all with micro inverters, ground mount, and was about 55 grand. Will take a long time to break even. Am banking on electric rates to keep on going up....
The last part is true in CA as well. All I do if/when the power goes off, I use my 2K Honda gen to supply power to the panels making them think they are still connected to the grid. Runs everything that way.Sweet. Here's the sad part... Indiana just passed a law last year that stops the turning of the meter backwards. So once your production equals your usage, there's no credit or storing it. Also, all solar/wind systems must now have an anti-backfeed system that prevents power from feeding the grid line if the grid loses power. They had several linemen get killed last year due to that they claimed.
how big a system?wow! I got quoted a shade under 20 grand yesterday.
Yes, just a small loss in efficiency.fog and clouds are essentially the same thing, water vapor, so would the panels still produce on heavily cloudy days?
hg on, ill pull it uphow big a system?
16.2 kW Grid‑Tied Solar System with SolarEdge and 60 Canadian Solar 270w Panelshow big a system?
ah i was understanding that it had to be installed prior to Jul 1 of last year. Thats good to knowAnd it looks like you can still get in on "net metering" in your state, till 2022. What I read.
Ground mount? Or on your roof? seems like a great price.16.2 kW Grid‑Tied Solar System with SolarEdge and 60 Canadian Solar 270w Panels
roof, ground mount is an extra 2k. The question is, this property is 98% wooded. I don't know if i'll have the room or if I'll have to clear cut a bunch to do it. i've also got an onsite consult scheduled from one of the local solar panel companies to get their engineer's opinion as well but its next monthGround mount? Or on your roof? seems like a great price.
Go for it!roof, ground mount is an extra 2k. The question is, this property is 98% wooded. I don't know if i'll have the room or if I'll have to clear cut a bunch to do it. i've also got an onsite consult scheduled from one of the local solar panel companies to get their engineer's opinion as well but its next month
