dukeboy440
Good, then he'll be forced to talk hahaMaybe he will be the one interviewing you...
Good deal for a set for the member that does not have them.
SUN Tune-up Testing Equipment Timing Light Dwell Tachometer Case + Manual | eBay
What to do first? I have a bunch of things I should do b/4 it rains. I need to back read and find the conversation between Dave and Ben about fertilizer and get some of that done today. It's supposed to be 70 and sunny.
Go ahead, you know you want it. If you delay, you'll kick yourself in the butt. What are you waiting for??That is so tempting...
Got any strawberries yet?
I always find things in the last place I check. Never makes much sense to check anywhere else after I found it.
Morning all....well I watched a couple U-tube videos for greasing trailer bearings, and it didn't look to difficult. Wife said NO, so taking it into the shop. The trailer has never been serviced (4 yrs old) so having an experienced wrench give it the once over is probably the way to go.
Barracuda goes in this afternoon to the upholstery shop. I'm replacing the convertible top, putting the correct dark blue top on it. With that I'll consider it done...for now at least, gee I'm not sure you ever get done with them....do you??
I know of a few people that are very good at that.Get to a point where everything works and stop improving it...
Or you will fix it until it's broke....
Maybe find a better used harness from something close to start with. Even if it's not right it will be closer than a Universal. Lay them both out and compare, change as needed...
yikes
Three to four hour drive is all it is to get there. Three days there. It was relaxing. Saw Elton john, front row 15 ft from the man! GREAT!!! And saw "O" at Bellagio. Pissed off a load of "Car" fund!!! O well....Shor trip, how was Vegas, Tim?
It was dark, i know it looks black, but it was just dark red. Strong smell, but not the worst.That ATF looks a bit off!
But you got some R&R. Its highly underrated.Three to four hour drive is all it is to get there. Three days there. It was relaxing. Saw Elton john, front row 15 ft from the man! GREAT!!! And saw "O" at Bellagio. Pissed off a load of "Car" fund!!! O well....
fair enough. So just to make sure I'm understanding your suggestion, are you saying to lay out the factory harness, buy the needed connectors,ends, plugs etc and get the same color wires and custom make a harness using the original as a pattern?
Welcome back Tim!I'm back all!!!
love trips but always love to be back at home. O And for sure gong to be in Carlisle. Sans wife!!!!Welcome back Tim!
About an hourView attachment 1715170808Filter was plugged, lots of clutch in the pan.
Front band was cooked and rear one was really loose.
Time to go order a band.
What? None of us got hit the other day.I guess Philadelphia isnt part of Pa.
He sure doesnt want to drive around this city.
I hate waiting on Parts...... If they could only send the right $hit the first time ...
For a new band, I suggest the Who...
Yeah...I was a Parts Store owner for 27 years...I like to use Rock Auto as a reference for correct part numbers, sometimes. They'll have several different manufactures part numbers listed there. Then I usually provide my own part numbers to my local suppliers. Believe me....The parts business is MUCH different today than it was, when there were still a lot of Independents around. I sold three stores to Carquest 18 years ago....
Put it in the oven on self clean.
The wife wont mind.
Uh oh.what happened.What? None of us got hit the other day.
