Ben Drinkin
Hey bartender!
Had one in a 90 model Bonneville. Sold it with 280k on it and it was still running strong..Those 3.8 L's are good engines...
The used cars guys were always snatching them up at the Auctions.. Made it hard to steal one away from the Auctioneer... They resold like hotcakes...Had one in a 90 model Bonneville. Sold it with 280k on it and it was still running strong..
Welcome back!Am back from deployment (mostly). It is the last one. 71 degrees, & a light wind at the beach; water is warm.
Well then, how about this...Here's one theme you may want to consider...
The last time it was out was to do a parade lap around Talledega in 1988 with the Winged Warriors Auto Club... Here's a picture of all of us in the infield between turns 3 - 4 staging for the parade lap....
That's my bil-Jerry, bro-Butch, dad-Spike, me, and my cousin-Pete...
Glad you're back safe..Am back from deployment (mostly). It is the last one. 71 degrees, & a light wind at the beach; water is warm.
Scampy is back!!!LOL sorry Scampy!
Thank you for your Service, to our Great Again Country.....Am back from deployment (mostly). It is the last one. 71 degrees, & a light wind at the beach; water is warm.
No, there is an internal part inside that blows through. Maybe it doesent apply to the engine in question. View attachment 1715229776
Never seen one do that...No, there is an internal part inside that blows through. Maybe it doesent apply to the engine in question. View attachment 1715229776
Edelbrock , Offy ???LOlI think we have aluminum intake... Hopefully....
A battery is a good example. After a run of -27 days battery sales go up. I remember a winterNever seen one do that...
Funny how tbe same motor will have different problems in different regions,here in texas on overheat weakest link breaks and there the weakest link breaks on hard freeze.
I figured that might be when I saw you rated a couple of my posts.Am back from deployment (mostly). It is the last one. 71 degrees, & a light wind at the beach; water is warm.
Pin type shoes on a '65?UUUggggg.. Trying to get the brakes , all new on the 65 Belve. 10x2.5 on the front. Didnt have self adjust, so I bought kits for that. Bought HD Centric , rivited shoes, but they got no pins for the adj levers...Been chasing parts all day , trying to find right pins.. Pia when you upgrade....Need larger dia pins for the HD shoes... Might just spot weld the smaller pins, to make it all work......
Im using the later system... Just need the correct pins for the shoes.....Pin type shoes on a '65?
AFAIK the pin type shoes and matching self adjusters were adopted across all Chysler car lines in Model year '69.
Either go with the earlier type, or go with the '69 type and matching hardware. Early style the adjuster pushes the adjuster cog down. '69 up the adjuster lever moves pushes the notched cog upward. '69 up shoes will usually fit earlier, but earlier shoes can not be used with the later system.
