Rat Bastid
Dunamis Metron
A zillion threads on connectors here. Whats wrong with 2 x 4 tubing with a plate on end welded to subframe.
I want the connectors welded to the floor.
I have heard that they dont fit well to the ribbing in the floor because every car is a little different, requiring a lot of weld to fill gaps. USCT IS Definitely not a project to be done unless the car upside down on a rotisserie. I did both of mine with 2x3 steel box tube layed on its side, and slotting the rear foot wells.
I have done 2 cars with 2x3 and lap plates on the torsion bar crossmember. Plenty strong, and cheap to do.A zillion threads on connectors here. Whats wrong with 2 x 4 tubing with a plate on end welded to subframe.
Discussing and cussing subframe connectors is like a politician or brain surgeon recommending a brand of motor oil!!I have done 2 cars with 2x3 and lap plates on the torsion bar crossmember. Plenty strong, and cheap to do.
I’ve been looking closer at sub frame connectors since I’m going to need them. What about the USCT connectors was it you weren’t fond of? I don’t mind fitting them. Was it you don’t like the way they weld to the floor?
I also need to duplicate your slider brackets. That’s a fall project.
Isn’t everyone that uses these ones say there the best because of that?Do not weld the support bars to the floor pan, ask me how I know
What did you use there? 2" x 3"? you did a real nice job! Perhaps what the factory would have done. Certainly what they should have done!Heres mine. Slotted at the rear and overlapping the framerail. E brake cable rerouted inboard of the connector so it runs parallel to it. I have seen people make big gaping slots in the connectors for cables. It kills the strength and looks like ***. I fitted this with a 4 speed setup. It clears the Zee bar well. Note the homemade torque boxes.
Pretty easy to see which way is best. Look what the factory did with the frame rails they used. Had they made these cars with full frame rails, they certainly wouldn't have left the center rails hangin in the air, would they? lol I really like what @moparmat2000 did in post #80. That really looks factory.Isn’t everyone that uses these ones say there the best because of that?
Ya, that’s awesome. KimPretty easy to see which way is best. Look what the factory did with the frame rails they used. Had they made these cars with full frame rails, they certainly wouldn't have left the center rails hangin in the air, would they? lol I really like what @moparmat2000 did in post #80. That really looks factory.
dummyI have a 1980 Dodge D150 and I'm having trouble finding anyone that makes frame connectors for it .....
I was talking about it's best to see what the factory might have done. Not necessarily what was strongest. I stand by what I said.No, it is not easy to see what's best. Comparing a spot welded, thin wall open box to a thick wall tubular connector is not obvious, if you understand how those are loaded.
As I have said before, unless you're going to do a full finite element analysis, which type is stronger is a wild *** guess. It's a guess for me, and I have structural engineering and materials science education. So whether you admit it or not, you're just guessing. You've got no idea which is actually stronger.
