I think you are right on the brown wire. Hard to see but it appears to go to the washer pump.
Frickin nice.......what is not to like ? outstanding!
Thanks for the response guys.
qkcuda, I'm sure now by looking at your picture that the brown wire is for the electric washer pump. Thanks for posting it!
69_340_GTS , You are correct that my car didn't come with an electric choke but I think the new wiring harness I have that's made by M&H for Year One may be more generic and include extra wiring that was used in later models up to 1975. BTW, does anyone know if later years had an electric choke??
Thanks again for the reply.
Hi Philcollins,About that green wire,which terminal (in the bulkhead) does it come from? I know there is a green wire going to the wiper motor...
Thanks Philcollins! Ill use these over the weekend and see if I can sort the wiring out.71 Plymouth Body Manual
http://www.mymopar.com/downloads/servicemanuals/1971_Plymouth_Body_Service_Manual.zip
and 71 Plymouth Chassis Service Manual
http://www.mymopar.com/downloads/servicemanuals/1971_Plymouth_Chassis_Service_Manual.zip
My M&H for my 67 didnt have a choke wire. I had to add that in.Thanks for the response guys.
What color is the wire?
Thanks 4spdragtop, I do have the foot operated pump but I believe the harness I bought has provisions for the electric pumpAwesome work! Hats off to you.
Im not sure but with washer pump would you need key ON and washer switch pushed IN to activate pump? (Depending on which switch you have) Some were foot/pump operated. Just thinking out loud...
