Thanks for the post qkcuda!
That should do the trick. Couple of questions.. will the fan I have mounted to my present clutch ( NOS Mopar clutch fan assembly) bolt to this?
Who did you order this from?
Thanks very much for letting me know about this!!!
Yes it fits standard Chrysler fans, mine is the MP 5 blade unit. I see Summit is showing them in stock. You may curse at me when you put it on, there isn't much room between the clutch and the flange to get the bolts started.
brings back memories my first car was a 67 cuda fastback in 1977. After 3 motors and 2 trannys i gave it to a local kid for his first car.
Looks awesome, great Job! Do you paint the the sheetmetal around the cooler and headlights flatblack?Thanks a56!
Ya, the tinted glass was one of the things I considered when picking the color.
It looks even better when the white interior is installed as the contrasts between all the colors is amazing!!
Appreciate you and everyone else who has posted following along with my build. Sure helps with the motivation especially when going through the tough times !!!
It looks mostly better on light colours, they did also from the factory. I'm looking forward to the finished car.Thanks plymouth4onthefloor!!
I'm going to mount the grills temporarily first to see how it looks, then Ill decide if ill black it out. Leaning towards blacking it out though.
Hey guys,
I need to set the ride height of my car with the alterkation front end components. As of now, the car seems really low at 30" from the top of the fender to the floor . Looks great but I don't want it bottoming out . It would be great if I could get ride height measurements from some of you members like the one I took in the picture.
Thanks much!!
