FomocoReformed
Fantastic work on that dash pad! Did you put any foam under it or just the carpet?
Looks great. Been wanting to add a console to my ride. What did you make it out of? Did you block the back so that the heat will flow around it? ANd last, how did you mount it to the floor?
Have you thought of mounting the dash on the lower A pillar screw? Also you could mount the Sunpro gauges in the console and put the ashtray back in and place your Ipod in there when listening to music with it plugged into the radio.
Sorry about that little tired. I ment to say have you thought of puttin the tach on the lower A pillar screw that is where I have mine and it is great.
Now if I can figure out what I did to kill the interior lights......**sigh** it's always something. I wonder if it happened because I pulled that map light switch out......I guess that is a problem for next weekend.
