bOb shingler
I hear you guys saying yours are working great but I can't help but wonder how much faster you could be going with a ladder bar set-up.
Okay guys just an update. John Calvert just got back to work after a cross country race trip & looked at the video of my car. Now he says its not spinning but hooking so good that my 60' times are slower, yet et is off two 10's. Does this make since to anyone? If it was hooking better why is it slower ? I did rethink the insatllation , and it dawned on me that when I put the springs in ,the center bolt would not line up with the spring perch on one side.(I could'nt even pry it in place) So I removed it from the rear shackle,loosely attached the spring with the u bolts to the diff., then tried to reattach but then the end of the spring was over 2 inches inboard of the rear shackle & I had to pry it in place while my brother attached the shackle! Also now my rear shackles are strait up & down versus being angled foward @ top like they should be. When I metioned this to Calvert he said that it should'nt affect 60' times, & came up with the above about hooking so good that the 60's are worse. I'm no rocket scientist, but with that much pressure on the spring sideways surely its got to be causing a problem! What do you guys think? All I hear is everything needs to be loose,so isn't this a contridiction?
If one needs more engine speed at the launch, then they need more converter stall speed not tire spin.
Here is some good info to read http://www.yellowbullet.com/forum/showthread.php?t=288916
that's what Im talken about...................................damit .......................Artie68 hemi dart, 528 race hemi puts 773hp and 676Tq. best on the foot brake was a 1.54, on the brake is a 1.42. we never really had a good track or enough time to tune it out but should go 9.80's if not into the 9.70's.
P.S. this pic is foot braking it, dont have a wheelie pic on the brake but its about 2ft high at Vegas with a cold track.
best thing you can do is film it and slow it down and see what its doing ,it took me years for mine to work watch these vids and see the car reacting
00131 - YouTube normal speed
http://www.youtubeslow.com/index.php?v=QWJVS1yTJss
lol that chevelle didn't even know what happened!
hi, a car that dead hooks will bog the motor through first gear. some wheel speed is needed to 60 ft better. reason, I have had dead hook before and lost 60 ft, raised launch rpm, can raise tire pressure, that will help some. then again , I'm not a suspension expert like skrews thinks he is!! funny thing is skrews has calverts under his car, lol. for him to bad mouth calvert is not right.
What about the A body cars, 20" front segments/transbrakes, that do run hard with cal tracs?
There are plenty out there.
slow speed 1.37 60 ft ,9.57 @142 3550 lbs
