I went with the cope racing bolt in, I think it’s about 100 bucks for the stock modified four bolt. There’s better sprags out there for more money. But a stocker should be fine if you’re on a budget.
Ill be doing one soon. 1 thing I haven't seen is a tutorial on is removing and replacing the bushings. Any insight on that would be great.
I cleaned it up with emory cloth and sanded down the support with some 180 grit. Was able to get it in with a block of wood and some tapping. Real tight. I think I will take a little more off and put it in the freezer.
Next question, my sprag was a little loose and some of the spring tabs were bent. I took it out and it has quite a bit of wear. So I plan on replacing it. Should I look at a bolt in or is a regular one good enough for my application?
I would definitely replace it...bolt in if you have the coin...
Jeff
send me your emailDoes any one have TF-2 instructions link or copy they can email? I can't seem to fine one.
