shootr2506
- Joined
- Oct 31, 2005
- Messages
- 130
- Reaction score
- 45
Yes on the dyno it made 637 hp at 5800 rpm and 647 tqr at 4700 rpmThose are impressive #'s since the big block 240s do 334cfm @ .700
That is excellent !Yes on the dyno it made 637 hp at 5800 rpm and 647 tqr at 4700 rpm
Should make 300 hpI’ll never know what numbers mine makes on a Dyno and don’t give a you know what. The drag strip will be my dyno, as long as I don’t get booted for being too fast without a roll bar....probably is a given so might as well go for broke then!
It’ll happen, just need to network with some locals and find someone thats done a van.....that’s “done a van”.....not “in a van”!put a cage in that sucker and let her rip.
Numbers from my local shop.
Intake. Exhaust
.100 70 74
.200. 133. 122
.300. 198. 164
.400. 252. 193
.500. 285. 212
.600. 298.5. 218
.700. 294. 221
.800. 294. 221
Nevermind the extra decimal points....stupid smart phone lol
No pipe. If/when they bring out a race head i wonder if it will be based off these castings or be something totally different?pipe on exhaust or not.
I heard rumblings of using a big block Mopar rocker. I think that would be a mistake.
is that a standard Mopar M1 manifold?I’ll never know what numbers mine makes on a Dyno and don’t give a you know what. The drag strip will be my dyno, as long as I don’t get booted for being too fast without a roll bar....probably is a given so might as well go for broke then!
It’s the last version of the LA Style with relocated outlet/bypass. The spread bore is Epoxied To a square bore. The epoxy is pinned to the aluminum so there’s no chance of it coming off and being ingested.is that a standard Mopar M1 manifold?
This isn't a Speedmaster thread....Surprised it can’t flow [email protected] when I can hit that 212cfm with a cheap azz speedmaster. After all this is a head aimed towards the street crowd (street strip).
This isn't a Speedmaster these.....
You must have mis quoted me...what???
Yes it would. They need to develop their own rocker, put the stands in the correct location and get it so you can run 1.8 rockers. I knew I’d think of other stuff.
