And that’s exactly why these heads will sell and sell well at these insane prices.That would be me. You're probably correct. I don't have the knowledge or the time to do port work.
"Panic" .... LOL...And just like that the “panic” has been brought down a notch.
Ya lets see some numbers.Any more updates on people's results with the TF 190 heads?
What kind of track times are you getting now with the Eddies? What kind of gains are you expecting?..Any more updates. I'm about to pull the trigger on these to replace my hand ported Eddie's..would be going on my stroker combo..along with a new solid roller.
408
12.3:1 (with TF heads)
Solid roller camshaft (still trying to decide on one, looking at the Lunati 40200734)
Frank Lupo Dynamic 9" 4300stall
4:30 gear
28" tire
150.shot nitrous.
408
4:30 gear
28" tire
150.shot nitrous.
I'm just flat curious for 3K what the gains are going to be over ported Eddie heads?No track is local to me so only had very few passes on the car. Unfortunately the only time I've gotten out, the car was having valvetrain issues and wouldn't RPM clean past 5800rpm..the car has been 11.64 N/A @3800ft.. with a hydraulic flat tappet.
Decided to redo the valve train and ditch the current cheap rockers I have now...and finally upgrade the camshaft...since everything is apart I'm also considering the trick flow heads.
Depending on who did your eddies and how they flow, you might not see any gains. Id carefully consider this one.Any more updates. I'm about to pull the trigger on these to replace my hand ported Eddie's..would be going on my stroker combo..along with a new solid roller.
408
4:30 gear
28" tire
150.shot nitrous.
Exactly I totally agree, that's why I'm digging and seeing what people have to say about them.I'm just flat curious for 3K what the gains are going to be over ported Eddie heads?
As opposed to making that hundred and fifty shot in to a 200 shot?
I'm with the advice of Extreme Caution...Exactly I totally agree, that's why I'm digging and seeing what people have to say about them.
my heads,I'm not too sure how well they were done...my local engine builder/machine shops son did them for me as some trade/side work. Never been flowed.
If I get the TF I'm sure I could easily sell my Eddy's to recuperate some $$$$
I think from all the speculation and the minimal amount of confirmation that you're correct would seem a no-brainer that these will out flow most any other aluminum head. The question seems to become how much more is needed than you already have. How much more do you want? For a lot it will be how much bang for the buck.... Personally I think for anything that see's a lot of Street time it's a bit of Overkill... Again I'm excited about the vacuum this is starting to create for the budget oriented people.... I'm already seeing ported very worked over great condition very low mileage Factory heads going for $400 and not selling...If your eddies have a 2.02 valve and the pushrod in the stock location, then the TFS will outperform. TFS is pretty honest about their headflow numbers and more than that they work really well in a real world situation. My buddy has the entire TFS top end on his 400” cleveland ford. They claim 620 flywheel hp on the ford. His car makes 550 to the tire and runs mid tens in a 3500 pound car. So they definitely have my respect.
Im with you but the goal here is ET for him and if he sells the eddies then maybe he will be in the TFS for 1500. Not too bad and he will get a bump in compression. When you are building a serious street strip motor there is no such thing as overkill. Especially when its a race gas motor to begin with.I think from all the speculation and the minimal amount of confirmation that you're correct would seem a no-brainer that these will out flow most any other aluminum head. The question seems to become how much more is needed than you already have. How much more do you want? For a lot it will be how much bang for the buck.... Personally I think for anything that see's a lot of Street time it's a bit of Overkill... Again I'm excited about the vacuum this is starting to create for the budget oriented people.... I'm already seeing ported very worked over great condition very low mileage Factory heads going for $400 and not selling...
I think we're both in agreeance but I'm just not on the pull the trigger right now side of the tracks. I'm more see what you get this year and see what everybody else is getting with the trick flow this year. I believe one good summer of people having these on will tell the story a lot clearer. "IF" he could (and I hope he would if he did) get $1, 500 for his old heads let's not forget how much he actually has into them now. I mean the loss he will take on the heads added to the new heads... Also at the price of never finding out the potential of what he had... Just food for thought...Im with you but the goal here is ET for him and if he sells the eddies then maybe he will be in the TFS for 1500. Not too bad and he will get a bump in compression. When you are building a serious street strip motor there is no such thing as overkill. Especially when its a race gas motor to begin with.
I definitely hear you there. I'm asking friends if they know anyone locally that has a flow bench that can see what these Eddies are doing. Living in Calgary there's not too many people doing this stuff.You are sort of in a catch 22 situation here. You don't know the flow numbers, so you don't know what you have, and you can't tell someone who is interested in buying them either. I would be hard pressed to buy a set of ported heads unless I personally knew the porter, or they were someone from a known shop. As for myself, I'm going with the TFS heads since I don't have anything, and by the time someone ports, or ships some of the alternative options, they actually cost more. My application is different though, as mine is a hot street effort, and altimate horsepower is not as important.
I do not mean to criticize, but my thoughts for your situation is to consider what some others on this forum have been able to achieve with the eddies. Tony Santos has regular mid to high 10s, Pittsburgh racer has achieved high 9,s with the Edelbrock head. Seems to me you are nowhere near maxing out the performance of the heads you have because other system on your car are not ideal yet.No track is local to me so only had very few passes on the car. Unfortunately the only time I've gotten out, the car was having valvetrain issues and wouldn't RPM clean past 5800rpm..the car has been 11.64 N/A @3800ft.. with a hydraulic flat tappet.
did anyone make 550 plus hp with the T.F. heads yet ? I have heard of high 400's . its fairly easy to get 530 -540 with the rpm's
I would go over what you have and see if other parts of your combo need to be addressed first. $3,000 is a lot of coin to spend only to get a marginal improvement if any. But I have no first hand experience, and this is just mho.
