Very nice pickup almost a second. Does the stroker have much more compression compared to your old setup.
The 394 is 11.8 to 1
and the 360 is 10.6 to 1
I’m hoping by fall/winter to do my upgrade from 410 w/EQ’s, Air Gap, and small .517” hydraulic to the TF’s, M1 single, low .600” lift solid and looser converter I have in the waiting. Does pretty well et/mph as it sits now considering my aero disadvantage, no idea on estimated or hoped for improvements in the 1/4 after being upgraded. May open up a can of traction worms but will see.Congrats on the killer times! We should see some more trick flow builds soon I hope
I totally agree. Port volume and a better designed port alone. At the time the Eddie's came out all they had to be was better than stock (street bolt on head wise). And they were, slightly.Guy i have always trusted/ respected a ton, Ken Hensley, Hensley performance, built me a 416 stroker shortblock long time ago... probably better than 20 years ago now.
I remember asking him if you had say a 340/360 and swapped heads, cam etc over to a stroker, how much is it worth at the track. He told me, all things being the same, 3 or 4 tenths. Never forgot that.
Regards the OP, and his large gain, besides the extra cubes, the BIG thing that jumps out is going from stock eddies to Trick Flows. Just a guess, but i wouldn't be the least surprised If there was 60 horse difference between just the two sets of heads, msybe a bit more. That and the inches is a lot
I have no complaints with Edelbrock heads. Curtis Boggs did mine and they went 6.57 @ 104 with a 1.38 60' in a 3260# street/strip Dart. The engine was 408", 10.8-1 with a 236/242 @ .050 flat solid, 727, 4.10 gears running pump 93.
My current 434 with ported Indy heads and intake, 700" lift solid roller has only gone 6.40 @ 109 with a 1.40 60' @ 3350# on pump 93. I'm hoping the new converter will get my 60' down where it needs to be and put me down in the low 6.30's. That .2 has cost me a hell of a lot of money.
Don
I'm thinking about bringing it to Bowling Green on Saturday to see what it'll do in the 1/4. It's actually set up better for the 1/4 than the 1/8. It needs a 4.88 or 5.13 for the 1/8 but I drive it so the 4.10 will do.
made tons of gear changes on different stuff and never seen much of anything at all doing so.
4.10/4.30 gear should be plenty with a good convertor to race it either way.... just my opinion, especially with a stroker crank.... assuming you dont have a big tire
315/50, 28". You're probably right on the gear. My 340 only picked up .04 going from 3.91 to 4.30's. The pick up was in 60' and carried it through the 1/8.
Found out the hard way. Most any small block, they like avoiding high gear in a three speed. 1 to 1 doesn't accelerate as quick.... lol...
My Little pooch motor i am running right now, had howling 4.10’s in it, swapped in 4.30’s thing hates getting put into high gear quicker... longer distance to cover
Want some 1/4 time slips buddy. Cool you are getting to leg her out
I'm looking forward to meeting you and looking over your Dart. I'll hide my junk, LOL.
wish you would bring your car.
My Dart is a pooch. Gettin old bro, dont like bending over the hood
Maybe in the offseason i will put my real motor in it, just keep puttin it off. Now that the hip is good, giving it serious thought now though....lol
Still wont run like your does. Either put these real mild eddies on it just to get in the 10’s, or at most trickflows.Flattop 418
We'll see how mine does at altitude now that I have a wideband. Last year I guess i was running SUPER lean, even though plugs looked decent. (By decent I mean they didn't completely melt).
408, 11.75:1
Trickflow heads
Super Vic
Howard's solid roller 257/267 .640/.645
4.30, 4800 stall converter (not built for this combo).
It didn't run that great last year. With all the tuning issues I had, but not bad for the elevation.
I understand, 59 here.
I'll be there for the test n tune on friday.You going to top gun next weekend?
wow, very cool! Could run low 10s when sorted out? I like it!!
Michael
