no doubt ! and thanks.
TTI claims I dont need the fancy starter with the 904 I am running.
I do have to loose my column shifter and get a floor one.
DJVCUDA .. i have a '66 cuda with a 318 / 904 combo .. i am wanting to do the exact same install with the same system shortly ... PLEASE keep this thread updated with pics and progress as you go .. VERY interested in following the journey ... also very interested in seeing if you go with the "X" pipe or "H" pipe (and why ?), and the differences between the two in sound AND performance .. what mufflers are you going with ?
thanks for the info man .. please keep it coming !!
Well it is best on the pipes to start per their instrucions from the tail pipes and work forward. Rear pipe fro mbumper, to hangers, then mufflers, then x pipe then bolt to headers etc.
Trust me , I tried it front to back and it is easier rear to front, you can leave it all loose and align it better and then they slip and adjust as needed. Once you clear the drive shaft, fuel tank frame, etc, get as much clearance as you can, you will need a helping hand to hold it where it needs to be then tighten her down real good.
I went all 3" man it is tight and very close to the large drive shaft i am running too.
Sounds and looks very good...
When I bought the tti system in the 2 1/2 inch size it was supposed to fit to the original manifolds. The passenger side would not fit because it couldnt get around the side of the 904. They had fitted it for a manual trans car. Hopefully you wont have that problem since you are doing headers. I later installed the shortie headers from spitfire. Lots easier to fit together.
