Wow! This wrap is a RPITA!! Way to many angles on my piping. I ripped it off. Gonna leave it alone for now...... Got the crossover and the Dp done at least.
Guess I will start putting the engine in and get it running. Getting tired of messing with it!
The wrap is a pain to put on. You can't see on mine but there are multiple cuts hidden behind the off angles and the next wrap of the pipe. Takes a lot of patience which I usually do not have.
Looks Good! I put on some spark plug boot sleeves. They are only 8" Long though. You can find it in a roll on ebay but there is only 1 color "white" that I found.
A good tip on the alternator I would use the one off of a newer dodge 135 AMP it will wire up the same way you can use the 70's regulater you just need to change the pulley to a V-belt trust me when all the electronics get hooked up you will need the extra amperage,the 95 AMP alternater is 4 5/8' diamenter and the 135 AMP is 5 5/8's .
You can find them on 95 to 98 dodge trucks ,I got mine off of 97 Ram that had a 5.9 in it,if your not sure what amperage it is just take a measuring tape with you.Oh yea looking good Cuudak!
"Hanger 18 mods"? Thats our set-up, that my buddy Andy came up with for the turbo Vega.
Thanks!!
I just got a wrench thrown into my plans.......... My good friend was over today and seen my 4 speed sitting on my roll-around.
He said,
You wanna 727 with reverse manual and a small stall???:cheers: Damn!!
I know its probably the right thing to install the 727.:banghead:
But I sold my pristine auto console and shifter a while back to a guy in California and I have this huge 4 speed hump in my floor(was like that when I got it)..
NOW WHAT DO I DO?????????????:sad8:
Any opinions??? I know it would be better for the turbo as far as keeping it under LOAD!
ARRRGGG!:banghead:
Keep the 4spd! Boost and a Manual Trans is some cool chitt. You will will be learning how to Brake Boost it then Look out!
Mostly a street cruzer I think it will live, you will never hook it on the street so it shouldnt matter, just watch the Bang shifting into 3rd at the track when you go. It will be fine!
Yeppers!
Seems that it works well from what I have read over on TTF... I also intend on boost referencing the rear metering plate w/powervalve per Holleys site.
I printed them both! LoL!
No disappointment here. Its your car, you should build it how you like. :glasses7:. I still think its cool with a full manual auto. And I think you might convert them to the might mopar after you blow their bowties clean off!Sorry folks!!
I was convinced to go with the full manual auto. I traded the 4 speed for the 727 with a bolt in sprag, reverse manual valvebody, red kevlar clutches and a 2800 stall. I know the 4 speed would have been a blast on the street but I have a few friends with their mid to high 6 second 8th S10's and Luv trucks that need their asses cracked by my streetcar!
I still think it will be just as much fun with the auto!
