Ridge
Lots of progress , keep it up
Good to know about 3rd gear being the weak link at 600 hp/TQ
Dremel took care of the sharp edges and I used a D.I.Y. coating from Tech line coatings after I blasted them with #120 Aluminum Oxide.Those pistons coated or just hand blended?
So when are you installing the real engine and firing it up?
Hey CUUDAK
Where have you been I want to see the end result of all your hard work.
I have been following your build for quite a wile. Your Cuda is going to bad ***.
Ridge
Trying, its soooo damn hot here. Their talking 104* Monday with 90% humidity! My metal shop is a Hot Box!
Uuuugggh... I don't think I will ever complain about the heat here ever again. On the up side with 90% humidity you might not need water injection ;)
Nice build, I really like that down pipe! Great idea
I herd it has been over 100 for three weeks or so in Texas ....
I thought we had it bad in Cal
vhtthe humidity is what kills me man im sorry. Forgive me if i missed it but what did you coat your hotside with?
