John Collins
Stress relief. Makes parts stronger.
How can you tell if it’s been peened?
I got mine from rock auto I just looked and they are out of stock now. But O'Reilly had them too.Nice!! Where did you find it, if you don’t mind telling?!?
Shot peening compresses the grain structure of the metal, "pre-stresses" it and makes it more resistant to cracking.
A shot-peened crank will have tiny pock marks (as Rusty mentioned above) on the non-machined (counterweight) areas, just as if someone had pummeled it with thousands of tiny lead shot pellets...which is exactly what they did.
It appears the weakest crank of the 3 types (forged, cast and cast/shot peened) is the cast-only crank which apparently only left the factory in the '72 340 (now you know why I changed mine to forged). My sources list ALL 360 cranks from '71-'86 as cast/shot peened. Hope this answers your questions!
Nice! Sounds like you're on your way. Now comes the really fun part...whip out your wallet!
No surprise to me...I lived it, John. One step forward and six steps back. Keep your dreams, don't let life's booby traps discourage you. And it will try.My wallet was extremely light and even lighter now since I just had a surprise $3000 vet bill... Basically my budget for the remainder of the build.
Hard to say from the angle of the pic on the block. The crank will be salvageable...they can generally be turned .030 under if need be. The scratch may polish out...your machinist will have to be your guide. Valves look pretty good but if it were me, I'd have the shop check the angles on the valves and seats for true. Better to build it right first time around...it's usually cheaper that way. Whether or not you can reuse the valve springs will depend on your cam grind. I reused my springs last time around and they were shimmed a little. This time I'll likely go with matching springs to go with the cam.How does the block look to you? Does it look like a three angle valve job on the heads? Is the crank salvageable after it’s already been turned and has a scratch?
No, can't really tell what the cylinder bores look like. When I blow them up they blur out.Awesome. I was worried about the crank since it’s already been turned... Hopefully I get good news from the machinist.
I’ll take better pics of the block. It’s in plastic cover and I was being lazy and only took the cover partially off for the pic... The machine marks don’t show on your end?
The cylinder bores seem great, smooth and without any imperfections in the metal. I was wondering if it looked like it had been decked.
Decking is done on the topside. Can't see that in the photos, unless I'm missing something:
If you're an exceptionally skilled welder.....Yeah, you can't really go 10 over when grinding a crank!
