Scody21
Just send it
It can cus you put too much load on the motor and stretched the chainValve chatter has NOTHING to do with cam duration/gear ratios.....
This is a Magnum engine,,,,,with hydraulic roller lifters .
The factory doesn’t recommend heavy weight oil with those .
In my opinion,,,,,the oil pressure is not correct .
An almost new engine,,,,with 25 pounds of pressure at 2500 r’s,,,,,nawww !
Tommy
That’s because the factory didn’t send it out with loose clearances.
I’m not sure why so many are struggling with using a higher grade oil to get the pressure up.
If I ran 20w50 in my engine it would over ride the bypass and blow the filter off.
If the OP tried to run what I use (0w20) he might never see 30 psi where I will see 90 or a skosh more on cold start and I’m figuring a hot idle of 45 psi at 1k rpm.
I’m not against using thicker oil,,,,,,the roller lifters don’t agree with it though .
The internal clearances in the lifters don’t like it .
My son used 10W40 for many maintenance free miles in his,,,,but never 20W50 .
If the pressure is truly that low,,,,there is an internal clearance issue somewhere in that engine .
Sounds like it has good power,,,,,just not good pressure .
Tommy
I don’t think he has a lifter problem,,,,,I think he has an internal problem,,,,or a bad gauge .
But,,,I don’t think it’s the gauge .
Evidence being of clatter at idle rpm,,,,,classic textbook example of low pressure .
And,,,,,low pressure around 2500 rpm,,,,another example of improper clearance somewhere inside .
When we fired my son’s new engine,,,,it was 75 at cold idle .
It was 45 at warm idle,,,,,,after the throttle was applied,,,,it was right back up there .
Runs at around 55 hot and at speed ,,,,,,really good engine so far .
I’m not trying to argue,,,,,just saying,,,,something is not right,,,,,roller lifters or not .
Tommy
Hi Tommy, yes I spent years building it up to this point. As you can imagine a lot of hard work. I'll post some more pics shortly. I'll see if I can find some before pics from when I first bought it 10 years ago.Man,,,,,,that’s a good looking son of a gun !!!
Beautiful car,,,,and paint,,,,and body style !
I would like to see some more pictures of that machine .
Tommy
On a Magnum?Wait, don't lifters spin while in operation?
A roller better not.Wait, don't lifters spin while in operation?
Did you install the computer for the seat belts as well? Just FYI for others newer 2001 up Sebring convertible seats don't require a computer to lock the belts like 96-2000 models do.Yeah, the Sebring seats idea wasn't mine, someone did it in a convertible Corvair and posted instructions online. The hard part was fabricating the seat mounts. The color is "Viridian" used on Aston Martin's in the mid-2000's. It's a dichroic color, looks kelly green in the sun and teal in the shade. The original color was that dark green metallic, so I wanted a green metallic but one that pops.
